Old 01-15-2015, 03:13 PM   #1
jump's Avatar
2013 30' International
lubbock , Texas
Frost in my fridge
Hey folks ... I'm in Houston in the AS for going on 3 months now and the fins inside my fridge are frosting like its a 50's model fridge.
Who has experienced this and what do I do about it?
Thanks for the replies.
jump is offline   Reply With Quote
Old 01-15-2015, 03:16 PM   #2
1999 28' Excella
New Orleans , Louisiana
We have a Dometic frig (propane and electric) that is new replacement. Have to defrost about every 4-5 weeks and fins get frost drips also. I also asked the same question a couple of months ago. Was told that is what to expect.
badkat is offline   Reply With Quote
Old 01-15-2015, 03:35 PM   #3
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Mine is ancient. Not sure if it's the original, but it looks like it could have come from 1974... It does the same thing. Not much you can do with this type of refrigerator. Household fridges today have an automatic defrost cycle that prevents this from happening. We don't have it on our camper fridges. Not sure if they provide that on an upscale model or not. Keep your door seals clean, and the door closed as much as possible, and that's about all you can do...
-Red, battling the ice like the rest...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 01-15-2015, 03:47 PM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The greater the relative humidity the more it is a problem. Also, door gaskets get old and this can worsen things.
Old 01-15-2015, 03:55 PM   #5
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Some models have a heat strip type thing made inside the frame that can be switched on to help prevent frost build up. Look for a small rocker switch up over the freezer area.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 01-15-2015, 04:13 PM   #6
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I want to try one of these in our Avion:
Smart RV Products Fridge-Fix Product #7
More info about their product:
Fridge-Fix
A comment from their site: "
With the Fridge-Fix installed, you will never have to defrost your refrigerator again.​​...ever."
Big claim to make....... maybe it works.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 01-15-2015, 04:16 PM   #7
2007 22' International CCD
Looks like a good idea...
KE4GNK/AE
Old 01-15-2015, 04:17 PM   #8
jump's Avatar
lubbock , Texas
So i just unload it and let it thaw?
Is there a circulation fan that fits dometic & might help prevent this?
Old 01-15-2015, 04:35 PM   #9
Panama Red's Avatar
Obrien , Florida
Fridge-Fix
Now that looks slick!
-Red, let it go, let it go...
Old 01-15-2015, 05:30 PM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Put the frozen items in an ice chest in hottest weather with dry ice in bottom. Meat and other reefer valuables on top of that. Canned outside if no more room.
Prop doors open. Have towels ready. Use hair dryer to speed process. Obviously a good time to clean it all and sanitize.
Inspect gasket on both doors. Look for age problems. Needs a little spring to it. No cuts. Etc. There are tests such as using a dollar bill to check seal. Gasket grips on bill or no grip. This is the big area of concern past cracks to the interior.
If door seal is good then fan can at help some. I like the one above but I wouldn't expect it to keep frost accumulation from happening.
A good floor model dehumidifier is what I use to lower the load on the A/C unit and the reefer in the TT interior.
The add on reefer fan should help with keeping interior temps more stable once in a drier climate or with dehumidifier. I shoot for 40%.
Old 01-15-2015, 05:39 PM   #11
Panama Red's Avatar
Obrien , Florida
Man, somebody has given this a lot more thought than I have.
-Red, duly impressed...
Old 01-15-2015, 05:43 PM   #12
PaulnGina's Avatar
Good Ol' , USA
Do you know the model number of your fridge?
Here is their fit chart:
http://www.smartrvproducts.com/fit-chart.html
1987 Avion 34W
Old 01-15-2015, 07:18 PM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I use a hair dryer to defrost the fins in the fridge, being extremely careful to keep the hair dryer out of the water drips. Less than an hour to get it done. For me it's usually about 6 weeks to 8 weeks till the fins get covered with enough frost to stop the air flow between them.
Alan
Old 01-15-2015, 10:00 PM   #14
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Thanks.
A big three-way reefer is expensive. And more than any other appliance it is at the heart of being able to live well independent of re-supply. And I've done this back to childhood.
Besides, I'm sure there are older threads addressing this and more. A search should always be done.
Making a 2-way Fridge into a 3-way Fridge? Bunkroom Refrigerators 18 06-03-2014 04:37 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 09:33 PM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
Frost on Freezer Door? glacierrunne Refrigerators 1 09-11-2008 10:41 PM
