Old 01-16-2015, 11:24 AM   #15
overlander
california57's Avatar
1957 26' Overlander
IRA , Michigan
Vaccume bag all your goods to, reduces moisture
california57 is offline   Reply With Quote
Old 01-16-2015, 01:26 PM   #16
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Wow, what an over-engineered solution for moving air inside the reefer. Too bad it doesn't actually deal with frost buildup. There are simple, much less costly ways to ensure a more rapid recovery from opening the door and adding items. Slowmover is on target.
Dometic Norcold Refrigerator Fan for RV 12 Volt | eBay
SeeMore is offline   Reply With Quote
Old 01-16-2015, 03:11 PM   #17
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
your Dometic Fridge is new enough it should have a built in frost reduction setting/control. Check your owners manual. Sandlapper described the control you should be looking for in a previous response. It is a small rocker switch at the top of the inside edge of the refrigerator or freezer door opening. Mine has one and it does work although I think it only works when you are plugged in to shore power. I don't use it often as we have low humidity here in CA and I'm normally not out for more than a week at a time.
Nomad518 is offline   Reply With Quote
Old 01-16-2015, 03:37 PM   #18
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
You can also double check the actual fridge temp. We were out for 12 days over Christmas, and I just turned on the fridge and set the temp selector at the middle position (it has five positions, total). Didn't think much more about it. When I finally checked the fridge temp, it was close to 30 degrees. Seems that I could have probably been running it on the lowest setting and been fine. That would have probably helped with the frost build up as well.
Cannonball is offline   Reply With Quote
Old 01-16-2015, 04:14 PM   #19
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Out of nine settings, I run mine between 2 and 3... Anything above three will ice the milk.
-Red, drinking some cold beverages...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 01-16-2015, 04:54 PM   #20
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
We found with our 72 Overlander that just a few minutes with a vacuum cleaner hose blowing air works about as fast as anything.. The air seems warmer than room temps,,, so must pick up some heat getting compressed and blown..
Anyway,, works better for us than the DW hair dryer. Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 01-16-2015, 06:24 PM   #21
mareinmn's Avatar
Why is defrosting the refrigerator such a big deal. We have been fulltiming in our34.5 for the last ten years with a close to original refrigerator. Like the man said use the hair dryer. I can defrost the fins and be up and running in 15 minutes. Really this is such a non factor. Just enjoy the ride.
Mareinmn but really on the Gulf coast
mareinmn is offline   Reply With Quote
Old 01-16-2015, 06:54 PM   #22
Panama Red's Avatar
Obrien , Florida
We've got to have something to talk about besides tow vehicle capacities and tire choices...
-Red, fin fan proponent...
Old 01-16-2015, 07:49 PM   #23
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Yep......it's the winter time blues. John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 01-19-2015, 03:23 PM   #24
2014 28' International
San Jose , California
At Quartzite, we just purchased a "Fridge-fix" from Custom Coach Connection. So far so good. What I have noticed so far ..... is that there is no condensation/icing on the fins. The temperature stays much more constant over a 24 hour period than previously. Now ... just gotta wait to see how long until the next need to defrost.
By the way, their advertising says that it keeps the food cooler and actually results in lower operating costs. He says it pulls 1 amp. He ships for free is you enter his discount code when ordering at fridgefixfan.com. His discount code is ccc.
Makaira is offline   Reply With Quote
Old 02-18-2015, 04:59 AM   #25
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I made my own version of the Fridge-Fix and so far so good. We installed it about a week ago. My version covers the front of the fins and draws air up and over the fins through an enclosed plenum. We're using the trailer for nearly three weeks so we'll know at the end of that time if it reduces the ice-up factor.
One thing for certain... with my three small fans blowing the temperature in the fridge is very consistent even with food packed inside. This was never the case in the past - we had to ensure the fridge was packed loosely and even then the temperature varied quite a bit from location to location.
I'll post pictures another time.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 02-18-2015, 06:56 AM   #26
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Originally Posted by jump View Post
So i just unload it and let it thaw?
Is there a circulation fan that fits dometic & might help prevent this?
Dometic rep told me not to use a hair dryer. I turn off the fridge, remove the top shelf, and prop my Endless Breeze fan blowing on the fins. Takes only a few minutes to defrost. I wipe the fins down with paper towels wrapped around a spatula so that they don't ice up again.
About every other time, I defrost the freezer as well as the lower box.
I do have a fan mounted on my fins. I wrote an article in Airstream Life an issue or two back about installing a fin fan. I ran the power to the fan up through the drain tube under the fins.
John W. Irwin
WBCCI #9632
Old 02-12-2016, 08:06 PM   #27
2015 23' Flying Cloud
Livermore , California
We have a 2015 FC 23. Is the Fridge-Fix a good investment?
cactusjk is offline   Reply With Quote
Old 02-12-2016, 09:01 PM   #28
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
I mentioned above that I made my own version of the Fridge-Fix and I think it works great. I forgot to post pictures and I hope to do that sometime.
Back to Fridge-Fix. It seems like a good idea to me and for ~$100 it would be worth a try IMO. My homemade version does reduce ice build-up although I still have to defrost periodically. The biggest improvement in my mind the much more uniform temperature throughout the refrigerator. I can put almost anything on any shelf and it stays cold now. Without the fans I found I had to leave the frig relatively sparsely loaded and the temperature at the bottom of the frig was several degrees warmer than the top, near the fins. Now I can load the frig to nearly overflowing and everything stays cold.
Lucius and Danielle
Making a 2-way Fridge into a 3-way Fridge? Bunkroom Refrigerators 18 06-03-2014 04:37 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 09:33 PM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
Frost on Freezer Door? glacierrunne Refrigerators 1 09-11-2008 10:41 PM
