Old 02-10-2016, 03:37 PM   #1
TankerIP's Avatar
2002 22' International
Question Frig will not cool on gas - works okay on AC electric
My RM2452 Dometic Americana has stopped keeping cold when using gas. It seems to work fine in AC power, I am in the process of trying to figure out what the problem might be and how to fix it.
I used compressed air hose to blow out around the combustion area. I switched gas bottles. i was getting enough gas to burn in the stove range and the furnace. The frig burner flame appeared okay, i.e, blue and about the right height.
I think I need to check the flue, but there is not enough room in the compartment to pull out the baffle wire for inspection.
I suppose I need to pull the frig out of its compartment, but I don't really know how to do it. Any help or advice would be greatly appreciated. I expect I will shut the gas off and uncouple the gas supply to the frig burner.
How heavy is the refrigerator? If I remove the two bolts at the bottom in the outside compartment, is that all I need to slide the frig out into the interior of the trailer? Some sites talk about getting something like a long bottle brush to clean the flue. Is this available at Home Depot?
Anything else that I am missing?
TankerIP is offline   Reply With Quote
Old 02-10-2016, 04:18 PM   #2
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Understanding it could be a number of things, I had this issue last summer on my dometic fridge. The principle check dometic had me undertake was to check the thermostat (thermistor check) by placing it into a glass of ice water for 10-15 minutes; then taking a resistance reading. Once it was shown the thermistor was working in spec range, it was deduced to be the lower circuit board. I forget now, but believe it to be about a $200 part, and one for which an electronics n00b such as myself was able to replace on my own, with success, that day.
Dometic has service manuals online in PDF format, which walk you through each and every step to check and validate each step, if you are so handily inclined.
good luck!
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 02-10-2016, 04:27 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Before you do anything else check to see if the burner is lighting.
You can remove the shroud at the base of the chimney and see the burner.
While looking at the burner have someone try to light the frig. If it does not light at all i would check the fuse on the control board. If it lights but goes out I would consider the thermocouple and take a small wrench and loosen it at the gas valve and retighten to make sure there is a good contact. You may have to replace the thermocouple.
If it had just been working you should be able to solve the problem without removing the unit.
2004 Excursion 4x4
Old 02-10-2016, 04:59 PM   #4
TankerIP's Avatar
Burner Lights Okay
I have not had any trouble with the burner. It lights and continues to burn. The canister that surrounds the flue remains hot (but maybe not hot enough) for days without allowing the the frig to cool enough (like it does on AC)
I removed the shroud around the burner and it appears to have a good flame.
Old 02-10-2016, 05:15 PM   #5
HowieE's Avatar
Images: 12
Well if it works on AC and has a flame when on gas that proves the controls and the sealed cooling system.
Possible problems may be a clogged chimney or reduced flame. Is the flame blue or yellow? Should be blue. Is the surface of the burner show any signs of dirt, rust flakes, on the surface reducing gas flow.
There is no easy way to check the chimney with out removing the frig or removing the vent cap on the roof.
2004 Excursion 4x4
Old 02-10-2016, 05:16 PM   #6
TankerIP's Avatar
So Ian,....Did you contact Dometic directly? Will they help you diagnose problems even if the unit is out of warranty?
Old 02-10-2016, 05:29 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like you are not getting good heat transfer. Something must be blocking the chimney.
Old 02-10-2016, 06:13 PM   #8
TankerIP's Avatar
That's what I suspect. And so back to my question, how to remove the refrigerator in order to inspect the flue. It looks like it will have to come out completely in order for me to have access to inspect, and clean the flue.
Old 02-10-2016, 10:25 PM   #9
CRH
1995 25' Excella
xxxxx , xxxxxx
Mine did not cool good on gas when I got it. The flame looked good. However, I was not getting enough gas. I adjusted the propane regular and solved the problem. Fortunately, mine has a gauge in the gas line right where it looks to the fridge.
CRH is offline   Reply With Quote
Old 02-11-2016, 07:31 AM   #10
HowieE's Avatar
Images: 12
Yes, before removing the frig test the gas line for pressure. It should be 11 in. If it is low your regulator on the tank may have failed.
2004 Excursion 4x4
Old 02-11-2016, 09:16 AM   #11
IanPoulin's Avatar
Aldie , Virginia
TankerIP --
I phoned them directly and although I was out of warrantee, their service help desk was willing to provide the information I needed to check the thermistor and ultimately replace the computer board.
Old 02-11-2016, 10:06 AM   #12
TankerIP's Avatar
I guess I give up
I have decided to try one of those "mobile RV repair" businesses. It seems I don't really know what I am doing, or don't understand how the frig works. I could have a pressure problem, or a thermostat/thermocouple problem.
I can't find a manometer, and I feel like I need to check the gas pressure. Home Depot no longer carries manometers...Amazon will deliver one next week...I need it now.
I tried to check the voltage on the thermocouple while the flame was on. It showed 0.0 mV (assuming I was checking correctly). If I wanted to replace the thermocouple I would have to pull the frig out since switches, thermostats, and connections go to the top of the frig -- a location that's inside the cabin.
I hate to give up, these things should be easy. But without diagnostic tools and understanding how this frig works, I might get in trouble.
Old 02-11-2016, 10:35 AM   #13
Corvallis , Oregon
Pull the fuel selector knob out and make sure the stem is rotating when you turn the knob. If it isn't try using a needle nose plier to make sure it's on gas.
boblind is offline   Reply With Quote
Old 02-11-2016, 10:43 AM   #14
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
TankerIP - I hope this helps answer your direct question.
The refrigerator is mounted with 6 screws usually. The two in the rear you see from the exterior hatch and four inside. The four inside are two at the bottom and two at the top. Some pieces of the plastic flashing need to be popped off to access them. On most models, the access is achieved by removing the covers at the hinges locations. Simply pry up the edge carefully; a thin insert works sufficiently. On others, both the hinge cover and cross piece need the removed.
Once everything is disconnected from the electrical and gas lines, the refrigerator slides into the interior space. I built a temporary table, four 2x4 legs and a rectangular surface (24"x30") of 3/8 plywood screwed vertically into the legs, at the height of the bottom of the refrigerator and placed it in the hallway. Once this is done, it is a one man job to push the refrigerator inside a few inches from outside, then go inside and pull it the rest of the way onto the 'table.'
The baffle is simply removed from the top of the flue: it is similar to a straight coat hanger wire with a 3" twisted piece of metal connected at the end. Clean it and the flue. I use a stiff wire with a small piece of scotch pad affixed with green flower wire to resemble a bowtie. The 'bowtie' need only be as wide as the flue because you aren't going to scrub the tube, just lightly brush the surface. Run it down the flue and up again. The problem, if flue related, is most likely a cobweb or other small obstruction like a flake of corrosion that causes the rising heat of the flame to flow improperly.
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Works Great On Electric But Not Gas raynickel Refrigerators 1 09-25-2015 05:46 PM
Domestic frig won't stay cool cegardner General Repair Forum 17 07-19-2015 10:15 PM
Rubber gas lines okay? 63air LP Gas, Piping, Tanks & Regulators 9 07-09-2014 02:14 PM
Fridge not working with Gas, still works w/electric Tim_S Refrigerators 3 09-02-2011 05:06 AM
Air conditioner works, but not cool starflyte1 Furnaces, Heaters, Fireplaces & Air Conditioning 50 09-25-2010 12:20 AM
