Old 05-21-2015, 09:47 PM   #1
1977 Argosy 28
new braunfels , Texas
Frig vent to outside?
I just bought a 77 28' Argosy tt. Everything original except it has a small house frig in it. I want to buy a frig for it. There is a outside door but there is no roof vent or any other vent to cool the frig. Should there be a vent?
If so were was it located? Thanks for the help in advance.
Signed Just Getting Started.
baddog0263 is offline   Reply With Quote
Old 05-21-2015, 11:25 PM   #2
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
On the inside of your trailer above the refrigerator, running from the counter top to the ceiling, should be a plastic (ABS I believe) chase. On the exterior, where that chase hits the interior ceiling, should be a cap about 1' long that is basically a rain shield. If the chase and the cap aren't there, then the PO removed them, and in order to put in a trailer friendly refrigerator, you will need to re-invent/install both components.
Others will have other opinions.
My 2c, and worth every penny.
DryFly is offline   Reply With Quote
Old 05-23-2015, 05:49 PM   #3
1977 Argosy 28
Thank you, I had no Idea. Yes it looks like PO removed it. :-(
Old 07-26-2015, 01:35 PM   #4
Geismar , Louisiana
Hmm I have removed mine... Is a vent like that really needed if you are using a modern DC/AC fridge? Or a simple mini-fridge from home depot/lowes? They don't expel any harmful fumes that I know of and as long as there is enough airflow behind it, it should be ok, right?
Danec020 is offline   Reply With Quote
Old 07-26-2015, 02:33 PM   #5
Mission , Texas
The vent is only needed when running the fridge on gas, or if it is an amonia cooling system in case there is a leak.
At least that's what I remember.
They say as you get older the second thing to go is your memory, I don't remember the first.
nrgtrakr is offline   Reply With Quote
Old 07-26-2015, 02:48 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Any ammonia absorption fridge needs to be vented regardless of the heat source. Thus is to allow for proper air flow across the condenser fins located at the top of the cooling unit.
If theyl get overly warm, it negatively effects the chemical process (which I won't get into here) going on inside the tubing and will not allow for proper heat transfer and cooling inside the box.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-26-2015, 03:16 PM   #7
Mission , Texas
What Lew said ...
I love the internet and my smartphone ...
Overview of ammonia refrigeration:
https://en.m.wikipedia.org/wiki/Absorption_refrigerator
RV fridge in application:
http://www.rvrefrigerator.net/Troubleshooting.htm
RV fridge more detail:
http://www.sundancecustomrv.com/Ammo...rigerators.pdf
The stationary engineer in me loves this stuff.
Installation with Hole in the Roof vs. Frig vent Mikec1231 Generators & Solar Power 6 10-27-2013 10:25 AM
New frig in 90 degree outside temperture silver 67 Refrigerators 2 07-06-2013 08:11 AM
Frig vent /battery box Canlib Refrigerators 4 07-10-2010 04:38 PM
Frig that vents out the roof vent only? Zstream Refrigerators 3 08-08-2008 09:27 AM
Enlarging a vent in an outside wall cindy Roof Vents, Skylights & Fans 1 07-19-2006 10:34 AM
