Old 07-09-2010, 10:22 PM   #1
1968 20' Globetrotter
Kelowna , British Columbia
Frig vent /battery box
I want to mount a new Norcold 512 in my Globetrotter. I'm planning to mount it in the original location aft of the door and above the wheel well. There is an existing exterior compartment door at floor level just in front of the wheel well that I was planning to use as a battery compartment. Will it be all right to vent the frig through the battery compartment floor assuming I use an AGM battery?
Canlib is offline   Reply With Quote
Old 07-10-2010, 07:59 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
AGM batteries can vent explosive gases under certain conditions. Because of this they are still required to be placed in a sealed container that vents to the outside of the trailer. Storing a potential source for explosive gas in the same area as a device with an open flame would not be prudent in my opinion.
Richard
Old 07-10-2010, 09:20 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I also would keep the battery compartment and fridge compartments separate. Vent them separately. Something to think about - what if the next owner puts a wet cell battery in that compartment...
Chris
Old 07-10-2010, 10:18 AM   #4
Maniacal Engineer
barts's Avatar
Menlo Park , California
Another vote for separate vents... I worry more about the possibility of sulfuric acid fumes from over heated batteries than hydrogen.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-10-2010, 04:38 PM   #5
Thanks for the info! I didn't know the AGM batteries off-gased. I'll put a floor in the fridge compartment and use a separate lower side vent for the fridge.
Ian
Battery Drain Frig bcmoore Refrigerators 6 05-27-2010 06:13 AM
Frig that vents out the roof vent only? Zstream Refrigerators 3 08-08-2008 09:27 AM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
Battery Box aztlanco Batteries, Univolts, Converters & Inverters 5 08-17-2004 05:56 PM
