If you are installing a Servel type refrigerator the answer is NO. This type of refrigerator works on convection, the movement of air up across the back of the unit. This requires a source down low and a vent above. If you look at the installation manual from the manufacture they go so far as to require that the back of the unit be no more than 1 in. off the back wall, something Airstream can not do and it effects the efficiency of the unit.
2004 Excursion 4x4
