Old 07-19-2011, 06:38 PM   #1
1964 22' Safari
Albuquerque , New Mexico
Red face Frig not cold enough
Does any one know how to get my frig colder. I turn up dial, but milk went bad.. any help .. 64 airstream original frig. Sandy
SPasquale is offline   Reply With Quote
Old 07-19-2011, 06:53 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Do a search "fridge"
Dave
Old 07-19-2011, 07:27 PM   #3
Mr & Mrs S's Avatar
Newton , Texas
Fridge
So people say to put a small fan inside the fridge to keep the air circulating inside. I tried that this time while we are camping and Im not having very good luck. Its staying just cold enough that our items dont spoil. This is only the second time our fridge has been used and its only one year old. So dont get your hopes up that a new fridge is going to be better. It got up to 114 degrees here today, dont know if any fridge can keep up with those kinda temps.
MR. & MRS. S
--Streamin & Gleamin--
Airstreamless, but havent lost our passion for them. Currently looking for the next project!
Mr & Mrs S is offline   Reply With Quote
Old 07-19-2011, 07:54 PM   #4
1999 34' Excella
Troy , Texas
Fridge
Does the fridge run at the same cooling level on gas as well as electric?
A couple of things to consider...adjust the slide glide cooling adjustment inside the icebox its on the right side of the refriderator cooling unit...just slide it down to where its level or flush to the bottom....if that does't work..my fridge would work fine...until I got on site and turned my AC on...the problem...the exhaust on the AC was blowing too much air over the fridge exhaust vent...thus it would not cool properly...that's why you see the fin mounted on the top of the trailer to prevent this...I put a fin on it worked fine...hope this helps....
excella99 is offline   Reply With Quote
Armstrong VCT - Any gluing issues with Cold? robwok Floor Finishes 4 08-08-2013 11:49 AM
Keeping frig cold on the road tstandefer Refrigerators 22 04-18-2012 06:55 PM
Cold weather starting - Yamaha Generators tberkhouse Generators & Solar Power 4 03-19-2012 07:25 PM
Cold / Hot Problems ? Tarheel-2 Full-Timing 4 07-11-2011 08:14 AM
AC - How Cold Should It Blow? dscluchfc Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 07:49 PM
