Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 11-25-2003, 08:15 PM   #1
Profile:
Thumbs up frig door swelled, will not shut
Bought '76 landyught. fridg door would not shut. rare item, impossible to find new or used. new fridg about $1400. Two choices ; fix door or replace fridg.. First choice; repair door. Moisture had gotten under the plastic liner & frozen the foam causing it to swell so the door could not not close. Had to split plastic close to rubber door seal & at the break over in door, peel it back, & grind foam all the way around, using 7 inch grinder (except the top) back to origional thickness. Re sealed plastic liner using pvc cement . Removed & remounted door several times until it fit the hole.
rockcutter is offline   Reply With Quote
Old 11-25-2003, 08:21 PM   #2
drboyd's Avatar
Profile:
Nice work!
Good to have you with us!
Now, if you could just fix my freshwater tank...
-Don
"Between what matters and what seems to matter, how should the world we know judge wisely?" E.C. Bentley, Trent's Last Case
Old 11-25-2003, 08:24 PM   #3
ARGONUT's Avatar
Profile:
Images: 8
WTG that the ole American pienearing spirit.
Johnny C.
If you can't change your mind;
How do you know you have one?
ARGONUT is offline   Reply With Quote
Old 11-25-2003, 09:20 PM   #4
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Same problem
I have the same problem and haven't got to it yet, just to many other things. Door will "sort" of close and fridg works.
Thanks for the info I will most likely use this as my solution. Can't stand the cost for a new one.
Garry
Old 08-02-2004, 04:32 PM   #5
Profile:
Hello Garry. Did you get your Fridg. door ground down so it will close? Mine looks a bit ugly when you open the door, but works great. 8/2/04 Dave (rockcutter)
Old 08-02-2004, 06:09 PM   #6
JohnG's Avatar
Profile:
Sounds like you did a nice job. You solution was impressive. Glad you shared your repair method.
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-02-2004, 07:28 PM   #7
garry's Avatar
Haven't got around to it yet but did print out your fix so when I do take the plunge I would have the info.
The door will close if you push "hard enough" but it still needs the fix.
So many things to do and so little time.
Now that I'm retired it makes me wonder how in the world I ever had time to work at a real (paying) job.
Garry
Old 08-02-2004, 10:18 PM   #8
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
Garry
I used to do so many projects while working. Among them were two complete sailboat restores . Now that we are both retired, I'd have just bit-the-bullet & bought a new fridge!
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
Old 08-03-2004, 07:01 PM   #9
Profile:
Hello, Ed. You should do your fridg. door on a hot day so the plastic skin inside the door should be easier to split. I used a heavy blade knife & light hammer for best control of split. I used 7'' hand held grinder body shop type.
Old 08-03-2004, 07:37 PM   #10
RivetED's Avatar
Hillsboro , Texas
Sorry, you must have mis-understood my post...My fridge is fine, BUT at this point in my life I think I would have just paid for a new one, too many projects & not enough time to get 'down-the-road'!!
