01-16-2008, 07:04 AM
2006 19' Safari SE
Central Part
, Maryland
Frig at 72 degrees, needs to be level ???
Well, I learned something new already today, hopefully not too late....
Came back to the Airstream yesterday (2006 Bambi 19) and the frig temp was at 72 and all food inside melted/junk. It was set to auto, seemed normal but just not cooling. I switched it over to gas only and it fired up and seemed ok, but still no cooling. The fins outside on the rear top of frig were nice and warm as usual but no cooling. So I shut it all off and figured I would look in the manuals today and see what was up.
So, this morning I make some coffee and pull out the manual and it says:
"the tubing in the evaporator section is specifically sloped to provide a continuous movement of liquid ammonia, flowing downward by gravity, through this section. If the refrigerator is operated out-of-level when the vehicle is not moving, liquid ammonia will accummulate in portions of the evaporator tubing. This will slow the circulation of hydrogen and ammonia gas, or in severe cases , completely block it, resulting in a loss of cooling."
I guess you never know what you don't know, but I had never heard of the need to be level for the frig. I am not off level by much, see pic 1, but we have been here at this campground for going on 2 weeks now, with just parked and frig running.
I am probably off-level side-to-side by maybe 2 inches, with curb side being high. Front-Rear is exact level. I searched thru the frig threads and read a bunch about being level etc, so I put my little level inside the frig (see the blurry pic 2) and you can see the bubble is high and considerably off center with the high side being the rear of frig (the frig is mounted on the curb side of Bambi so the rear of my frig is what is the "high side"). But it is certainly not uncomfortable off-level, but slightly.
So, let me finish my coffee, I will hitch up and pull forward onto at least one, maybe two, 2x6's and get dead-on level. I'll then start frig back up, cross my fingers and hope I didn't fry anything, and then will watch the frig temp guage....
I will advise of my success or failure....
:-) Dave
Dave&Shari Wagner
2006 Bambi SE,
2008 Ford F350 Diesel 4x4
AIR#23096
" I am lost and have gone Airstreaming to find myself, If I should return before I get back, please ask me to wait..."
01-16-2008, 07:11 AM
Airstream - Other
Bosque Farms
, New Mexico
Yeah, our new fridge is really sensitive, too. During our fall trip, we were just a little off level, and the durn thing wouldn't cool properly. We had some frozen garlic cloves in the freezer compartment, and when those defrosted, they really caused a smell!
I really miss our old, original fridge, which would work in just about any position and which was a lot bigger anyway.
Lynn
ACI Big Red Number 21043
01-16-2008, 07:17 AM
Aluminut
2004 25' Safari
They way I understood it, or I should say it was explained to me is that older units are more prone to this than newer units and that newer units, if it's comfortable enough to reside in the trailer, it should be good enough for the fridge.
Though I am a little shocked that the newer Bambi had issues like this, one thing that the Bambi doesn't have is a flue like most of the larger units. It has two outside doors, and a fan. I had an 03 Bambi and currently have an 04 Safari, I followed the rule of getting the RV in both circumstances as level as possible....mind you I was never really far off "zero bubble" as you've described and I did not have the same exp, even in very warm outdoor amb temps.
01-16-2008, 07:22 AM
1993 34' Excella
Estancia
, New Mexico
I have heard multiple times leveling older fridges is more critical than newer ones, refering to them as "old amonia units". Is there another system in use than amonia in newer units. It sounds like some of the newer units may even be more sensitive to being level.
01-16-2008, 08:05 AM
2006 19' Safari SE
Central Part
, Maryland
"Dead-on, balls-accurate, level"
Well,
The trailer is now "dead-on, balls-accurate, level"....
I also rocked the trailer side to side as much as I could and went up/down on the jack a couple times to maybe see if there are "ammonia pools" in the lines that maybe they will shake loose.
It's 10 AM and the frig temp is 74.7 degrees so I have fired the frig back up and "crossed my fingers".....
I'm not even going to look at the thermometer until 11 AM cause I don't want to jinx it....
regards, Dave
Dave&Shari Wagner
2006 Bambi SE,
AIR#23096
01-16-2008, 09:28 AM
2006 19' Safari SE
Central Part
, Maryland
Success !!!
All Right !!! Success !!!
This is 1 hour later and down to 48.6 degrees.....
I still can't believe being off level by just one 2x6 (see pic 2) made the difference. I guess though, since we have been here so long without any real movement, that the being just a little bit too much "off-level" was the issue.
So so much for the theory that newer frig's are not as sensitive. This is a 4 cu ft Dometic.
Anyway, live and learn... I will be much more aware of levelling anytime I stay more than one night in the same place.
best regads, Dave & Shari....
now I have to go out and buy some more steaks to replace the ones I had to toss...
Dave&Shari Wagner
2006 Bambi SE,
AIR#23096
01-16-2008, 10:08 AM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
That's a real surprise - that such a small difference can affect cooling. Thanks for the warning.
Pat
01-16-2008, 11:03 AM
2004 30' Classic Slideout
Fenton
, Missouri
I heard the same thing that Eric pointed out, that the newer units were more tolerant of the level not being perfect. However with all of that in mind, I always have attempted to get the trailer as close to dead center as possible.
Keep in mind that if the temp is affected by running off level, it's also a situation that can damage the cooling engine of the fridge.....so it's more than just the situation of food spoilage. You can cause a clog or build up of materials within the tubes since the gases and liguids are not traversing the system properly.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
01-16-2008, 11:17 AM
2006 19' Safari SE
Central Part
, Maryland
I think it was mainly an issue of being here lots of days with no trailer movement. The frig stopped cooling after 9 days at the same campsite with no movement, so if the gasses tend to "pool" up I guess it sort of makes sense that after a lengthy time they eventually puddle up enough to plug off a line. Sort of like the "S" bend in a drain pipe.
Anyway, looking good now so I'm happy and hopefully didn't hurt anything. Sort of makes me wonder though about what other things I don't know. I honestly had never heard or knew anything the issue of a frig needing to be level in order to work properly. I always thought levelling was just a creature comfort thing.
Anyway, did I mention that we are in Key West ??? So there is only a limited amount of work I can do in a day, and I think I have now reached my quota so we are done... Shari is already in her beach chair - I am heading for mine...
best regards, Dave & Shari
Dave&Shari Wagner
2006 Bambi SE,
AIR#23096
01-16-2008, 12:13 PM
_
nice pic wagnerda!
if you've not read artstream's fridge thread, it's pretty funny...
he found BEATING on it with a big stick greatly improved performance.
no foolin'
imo new fridges are less prone ONLY because they are new.
once deposits and changes occuring inside the coils level really matters.
also IF you look at the back side of the fridge it's easy to see which direction of unlevel...
is gonna be more problematic.
I have always kept a small bubble level INSIDE the freezer compartment..
and us that reading as the primary goal when parked more than a day or 2...
but you are correct there are SO MANY little issues to deal with on these babies...
you've got the ideal spot now for reading the manual...
cheers
2air'
01-16-2008, 02:30 PM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
Changes in altitude, changes in attitude.
01-16-2008, 05:54 PM
1975 29' Ambassador
Reno
, Nevada
I think the new ones tend to protect themselves in ways the old ones didn't. The auto shutdown may have needed a bit of persuasion to get unstuck or something.
Generally, if the rig is level enough to be comfortable then it should be OK for the fridge. See Leveling for some more on this.
01-16-2008, 09:42 PM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
Thanks for the heads up, Dave. I had also heard that the newer ones were more tolerant than the older units, so this is good to know. Based on my experience with the 68 Trade Wind, I always shoot for perfect level. I've had the refrigerator in the 05 Bambi running almost constantly since we bought it with no problems.
Nice pic. I haven't been to the Keys in over 30 years. I'm sure things have changed. It's 28 degrees here.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
01-18-2008, 09:25 PM
2006 19' Safari SE
Tucson
Hey Dave and Shari...glad you are enjoying the Keys...2 weeks! Good for you...what a life, eh?
I am surprised by the frig problem that developed...I had also been told that newer units are not as sensitive to being level and that if it's comfortbale to be inside that the frig will be just fine...though I was aware of the need for "levelness" in general...
You are probbaly right that length of time not moving might be a contributing factor. We leave our frig running at home when it's under the Bambi port on a shore line since we try to get out about at least every other weekend for a long weekend if we can...and we have never had any problems. Thank goodness, it is pretty level there or we might have a similar problem.
Being level is relative sometimes, we've found...depending on WHAT you are going by as level. We found this to be the case particularly in our former SOB motor home... We finally started using the floor as our reference point since the sink counter, the counter over the frig, and the dinette table never seem to agree...perhaps we should change to the freezer compartment as out "level" point like 2air' suggests. Another trick I've used is to fill a glass (one you can see through the side of) 1/2 full of water and sit it in varioius places to see if the water is level...(glasses with designs of horizontal line of some sort are particulalry useful).
At any rate, glad you got it resolved...and you could get back to the task at hand...vegging out on the beach. Sounds nice.
This weekend we are hold up in Gilbert Ray Campground on the west side of the Tucson Mountains...just 15 miles from downtown Tucson...looking west to sweeping desert views and gorgeous sunsets...days in the 60s and nights in the 30s...chilly for us.... No water in sight, so enjoy your view for us!
TB
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
01-18-2008, 09:38 PM
Naples
Hey Gang,
Mind if I join this party? I have the same 4 cu. ft. Dometic in my CCD. According to Dometic, it only has to be level so that the trailer is 'comfortable to walk in' which amounts to 1/2 bubble if you're into levels.
The older units with the square boiler sections had critical leveling requirements because the drop in the tubing did not allow proper coolant flow in any slighty out-of-level conditions.
Another problem you may be experiencing is condenser overheating. Airflow in the back of the fridge is CRITICAL to proper operation of the cooling unit. If the condenser gets too hot, your fridge will not get much below 50*. The solution is either a Snyder's fan kit (very efficient and thermostatically controlled) or a fan blowing up from the bottom vent and one blowing out from the top vent (on your 19'). Also, the absorber coils should be no more than 1-1/2" from the side wall to create proper air flow. You might check this distance to assure that the 'chimney effect' is working.
I have run mine at the 1/2 bubble position wih no problems! Check your venting.
lewster
01-19-2008, 02:55 PM
2006 19' Safari SE
Central Part
, Maryland
Hey Lewster,
I honestly don't know what was/wasn't wrong with the frig. I know you are techy in nature so here is as much technical info as I can give. This is the very first issue of any sort with the frig as it has worked flawlessly for 2 yrs.
But, after 9 days at this same campsite without moving (and I mean not moving - Shari hates any movement so stablizers are cranked down hard) anyway, after 9 days, running on electric, the frig stopped cooling. But at the same time the fins at the top rear of frig were "hot" and the fan (factory standard) was running away so everything was looking as normal. It was around 80 each day and high humidity. Now, I will also admit that the curb side (rear of frig) of the trailer was maybe, maybe, 2 inches high. By putting a 2x6 under the street side I came up exact level.
When I put the block under the street side tire I rocked the trailer side to side as much as I could, and went up/down on the jack. Literally within an hour everything is back to normal.
So, IMHO, something slowly plugged up over the course of 9 days enough to plug up a line. It wasn't as if the frig had shutdown or anything, it was trying to cool, but just not cooling.
So, I think it gradually built up in one of the lines and and then plugged it shut so even though it was trying to cool, it could not cool.
That was 6 days ago now and frig is just fine ever since so......
My thinking is that is you have a Dometic and are staying for more than 1 week in the same spot pay extra attention to exact levelling. That is what I will do from now on, and I will advise if any further issues.
Even with that being said, I do plan on installing one of the Snyder frig fan kit deals one of these days, but that is my second fan priority as the frig fan is not that noisy or bothersome. My first absolute priority is to get rid of the range hood vent fan as it just drives me crazy....
best regards, Dave
Dave&Shari Wagner
2006 Bambi SE,
AIR#23096
01-20-2008, 07:13 AM
Naples
Originally Posted by wagnerda
Hey Lewster,
best regards, Dave
Hey Dave,
Smacked your head a few times on the range hood....have ya? Me too!!
It sounds like you hit the nail on the head with the blockage thing. You got it just in time. The temps on the cooling unit should be evenly warm across the whole unit. would think that your condenser was hot and the rest of the unit was much cooler. It should also mix up a little when you are driving......
lewster
01-20-2008, 07:25 AM
Retired.
, At Large
Lew, that's yet another reason to keep camping. If anyone wants, I can snap a photo of the 12v computer fan I put in the back of the fridge compartment. It doesn't blow directly on the coils, but rather helps create a draft up and out, enhancing the natural convection process.
Many of the newer coaches have this fan installed at the factory, with a switch by the door.
01-20-2008, 04:00 PM
Naples
Hey Terry,
I had that fan with the switch on my 19CCD. Unfortunately, it was in the wrong place and was blowing IN.....not OUT! If you are using the independent fan method you really need one at the bottom of the fridge or underneath the condenser....and another blowing OUT at the top vent. I discussed this probem at length at Dometic, and they ae now using 2 cooling fans on their newer large fridge units. FWIW, the Snyder's kit really seems to do the job.
lewster
