Old 08-31-2015, 10:52 PM   #1
2014 23' FB International
San Diego , California
Fridge won't work on LP
We have a 2014 23' FB. It has been stored indoors since our purchase in Nov of 2014. On our maiden trip today, the fridge will not work on LP. Battery is in use mode, propane tanks are full, stove lights and burns properly. When the fridge is turned on in auto mode, the check light comes on in seconds. I tried the suggested method of turning it off and on three to four times. I opened the outside access and checked the value. It is open. I have not tried it on AC as there are no hook-ups at the campground. I do have a 2000 watt generator available and could try it that way. Any ideas, or do I just have a problem that needs service? It is still under warranty. thanks for any advice.
jeffmimi is offline   Reply With Quote
Old 08-31-2015, 11:17 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Burn a stove eye a few minutes. It helps purge the gas lines of air.
CRH is offline   Reply With Quote
Old 09-01-2015, 11:53 AM   #3
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
I would first fire up the genny for a while and see if it starts to get cold. If so you can then begin to narrow it down. When I have problems like this (and it has happened a couple of times - I even carry coolers with me just in case...) it is quite often a dirty burner. Soot can fall down from the flue and clog it very easily as it only has a very small flame (kind of like a candle). That is where I would start (not with it hooked up and running on AC though!). Of course yours is new so it likely isn't dirty. But yes it will likely need to be serviced/checked out by a dealer. I think the fridge has it's own warranty and can be checked by any authorized dealer of that brand IIRC. CRH is right about firing up the stove, but it sounds like you already did that.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 09-01-2015, 12:09 PM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Another area to check is the flue. Sometimes a spider will enter and spin a web which will prevent the draft from flowing through the vertical tube (chimney flue). You may be lucky with a coat hanger inserted in the first few inches.
You need to be careful as there is a wire that drops down from the flue top on which there is a thin, twisted aluminum ribbon that causes just enough slowing of the draft to heat the chemical mixture in the small tube mated to the flue.
The proper way to clean the flue is to remove the refrigerator, then the baffle from the top of the flue, and use a brush similar to those used to clean rifle barrels. Anytime your trailer sits for long periods, the bug issue can arise. Your manual will mention this preventative maintenance and schedule.
SeeMore is online now   Reply With Quote
Old 09-01-2015, 12:35 PM   #5
1978 Argosy 24
MooreHaven , Florida
Are you aware that these fridge units take several hours to get cold? Could it be that you just have not given it enough time? I usually turn ours on the day before we plan to use it,that way it is down to normal temp when we need it.
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 09-01-2015, 01:20 PM   #6
1974 Argosy 20
Kooskia , Idaho
If the rig has been in storage for quite a while, and not properly charged, the batteries may be down below the point that the refrigerator will work properly. It takes a good 12 volt system to operate the controls and the sparking system for propane operation.
Just one more possibility as to why it will not light on propane.
Old 09-02-2015, 10:16 AM   #7
Rico2surf
Medford , Oregon
Fridge won't work on LP?
Don't know about the newer ones, but I have a '73 Overlander which I replaced the fridge in and it didn't start up on propane either. I discovered that it has to have a 12V line to it to have it work properly, run thermostat . . . ignite. Just a thought.
rico2surf is offline   Reply With Quote
Old 09-02-2015, 10:25 AM   #8
chriscraw's Avatar
1991 35' Airstream 350
Correct..12VDC must be present to run the fridge on LP gas. I found this out the hard way after spending some $200 to replace the control board (from Dinosaur Parts) onlt yo find the problem was a blown 20 amp fuse on the DC circuit.
chriscraw is offline   Reply With Quote
Old 09-02-2015, 10:27 AM   #9
Thiatt55's Avatar
2016 30' Flying Cloud
Truckee , California
Check the fuses!
I had a similar problem with not switching to Electric. After waiting 8 weeks for service appt. it turned out to be a fuse. BY THAT I mean an internal fuse inside the refrigerator. Not sure if propane system relies on a fuse but worth checking out. Fuses (2) were in small box inside the refer. Odd size fuses so now I carry replacement fuses for all items in the AS for the MANY inline fuses that exist. Such as refer, range hood, fantastic fans, water pump, trailer hitch lift and of course the ones I have yet to discover.
Thiatt55 is offline   Reply With Quote
Old 09-02-2015, 10:35 AM   #10
1969 21' Globetrotter
Calgary , Alberta
Silly, but obvious question...is your rig level?....LPG appliances like to be level to operate.
CDNCampers is offline   Reply With Quote
Old 09-02-2015, 11:47 AM   #11
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Have you tried to light it manually? Open the access door on the outside and remove the flue small access door,Have one person inside to switch to on and one person with a lighter on the out side when they signal you light it (or you hear clicking)If it lights it should stay lit until you shut off the fridge.If this works you need a new circuit board.If under warranty have them replace it and order a Dinosaur circuit board ($100) as they are much more reliable than the factory circuit board keep the factory board for a spare.
You might check the fuse on the refrigerator circuit board also when you have the access door open.
I have had a board go out while boondocking and lit mine manually and it ran until I got home 2 weeks later.
Old 09-02-2015, 01:03 PM   #12
1984 34' Excella
Spruce grove , Alberta
Can you hear the DSI sparking when you select gas? Most will keep sparking for up to 3 minutes.
As stated before id try to light manually with a BBQ lighter and also verify the gas is turned on at the back of the fridge. Usually there's a valve in the line.
WW2GURU is offline   Reply With Quote
Old 09-02-2015, 01:39 PM   #13
2013 16' Sport
Boulder , Colorado
This has happened twice to our fridge. After trying all the suggested fixes, both times we ended up taking it to the dealer to have a bad motherboard replaced ( under warranty). Evidently they are notoriously faulty.
Caroline
Seecue is offline   Reply With Quote
Old 09-02-2015, 01:46 PM   #14
Calgary , Alberta
Have to comment again to the newer trailers...our 1969 fridge requires no power at all to run on LPG. Lights every time, gets cold fast and can still make ice. Wondering what made them decide to make them so technical?
Fridge won't work on electricity or propane jhenschen Electrical - Systems, Generators, Batteries & Solar 32 07-08-2014 09:24 PM
We won, we won!! Cyberous Friends of Dorothy 37 02-01-2013 10:08 PM
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 09:19 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
I won, I won!!!! till Off Topic Forum 13 11-28-2004 07:17 PM
