Old 09-02-2015, 02:55 PM   #15
Britbat's Avatar
1975 27' Overlander
LaVale , Maryland
Dauber wasp nests in the jet was what ours was.
Britbat & the Shiny Beast
Britbat is offline   Reply With Quote
Old 09-02-2015, 04:24 PM   #16
2014 23' Flying Cloud
Rhinebeck , New York
Dear Jeffmimi,
Thanks for your post as it is a reminder that I may still have the same problem. We have the same Airstream; 2014 International Serenity 23'fb.
I had already replaced the original water pump after two one week trips of use last summer ($#&%) and on the first trip (and only) this summer we experienced your problems. I was parked in a State campground without hookups . We had problems keeping the refrigerator working. I intended to use the onboard gas system and if required back up with the batteries (generator/truck to recharge). WE have a new Honda 3000i. Well, I am still not sure why the gas didn't work. All I know is we selected gas/auto. What ran the refrigerator was likely the batteries as they showed red each morning. Generator was used/truck to recharge.
I admit to being a type of person that gets a bit rilled when this stuff happens which prevents me from being being very useful in determining what needs to be done, at least initially. I have limited knowledge of the unit's systems operation. We kept trying gas and again was never sure what was actually firing the refrigerator. Stupid perhaps??
Bottom line, I will recheck our Airstream tomorrow. I'll try igniting the gas system for the refrigerator from the outside as has been suggested assuming it doesn't ignite on it's own when selected. The next step is to take the Airstream to a nearby RV center.
Good luck solving this problem. I'll report our experience/solution.
Adam
Adam Geuss is offline   Reply With Quote
Old 09-02-2015, 05:44 PM   #17
2010 25' FB Flying Cloud
Snoqualmie , Washington
Had this happen to us a few weeks back. Ended up taking at least a dozen times turning it on and setting to gas, then turning it off. also hooked up generator for a minute - just to make sure it worked. Did this over an hour (while looking for other causes) - and finally it just started. No problems any other time.
Anders79 is offline   Reply With Quote
Old 09-02-2015, 07:33 PM   #18
1967 26' Overlander
Spartanburg , South Carolina
Our '67 fridge is a ditto to CDNCampers'. They got technical, I think, trying to make them idiot proof so they can automatically switch back and forth as available power changes.
Jacob D is offline   Reply With Quote
Old 09-03-2015, 06:53 AM   #19
Montrose , Colorado
Burner orifice
You probably already know this but if not, elevation matters a great deal on your gas appliances.
I ended up having to replace the water heater burner assembly with orifice to get it to work at 7,500 feet. Went down to talk to my trailer guru and he informed me that they were having a problem with ALL the new model REFRIGERATORS and there is not a replacement burner assembly for high altitude for the fridges. He said it is a matter of fine tuning the gas pressure regulator with the air flow depending on altitude. Not every camper lives at sea level and I do not understand why they set the appliances for sea level. Hope this helps.
VickieB68 is offline   Reply With Quote
Old 09-08-2015, 04:36 PM   #20
1969 21' Globetrotter
Calgary , Alberta
VickieB68 we have no issues with any of our LPG appliances at elevations. We have camped at 10 feet above sea level and the next day at 7500 feet and everything works all the same. Perhaps they need to start building the pre 80's appliances again. They just work! No moving parts...no battery required!
CDNCampers is offline   Reply With Quote
Old 09-08-2015, 05:11 PM   #21
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I may be late to the dance however when this happens to me I do the following. First ensure u have propane tanks on (I know obvious) then light gas burners. If they lite then u know propane is flowing. I then turn the refrig on to LP mode. If the lite is not blinking I know gas is working for the refrig, if LP light is blinking I turn the refrig off for about ten seconds and turn it back on if light is still off I do it again. Other then that make sure no bugs are blocking anything
urnmor is offline   Reply With Quote
Old 09-08-2015, 05:24 PM   #22
chaseav's Avatar
2015 25' FB International
I had this problem before and experienced on and off every time I took the ship out of storage. The common thread: When I go to storage I turn off and disconnect the LP tanks. When I reconnect, there is no gas in the lines so the fridge, in its infinite wisdom, thinks this means I ran out of propane and goes into lockout mode. There is no great fix to this other than to turn on the stove and fill the lines with gas. That doesn't help the air that's still trapped in the line by the fridge but eventually (3-4 attempted and failed starts later) it finally connects and lights. You may need to unplug the fridge outside to reset it. The manual says what to do once in lockout mode.
Can you hear the tick, tick, ticking? It's really quiet but if not, you probably have bigger problems.
chaseav is offline   Reply With Quote
Old 09-26-2017, 01:56 PM   #23
penrose , Colorado
I am having a similar problem....fridge works great on shore power but will not ignite when on gas mode. I can however manually light it but once the fridge reaches temp it shuts off and will not re-ignite. The electodedoes not "click" either. Is this a bad circuit board?
Flyfshr1973 is offline   Reply With Quote
Old 09-26-2017, 02:00 PM   #24
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by Flyfshr1973 View Post
I am having a similar problem....fridge works great on shore power but will not ignite when on gas mode. I can however manually light it but once the drive reaches temp it shuts off and will not re-ignite. The electodedoes not "click" either. Is this a bad circuit board?
Hi
No clicks could be a bad circuit board. They could be a bad igniter coil. They might be a bad thermocouple. They could be a loose connection to any of the above. Time to get out the multimeter and start tracking things down. If that's all Greek, head over to just about any RV repair shop. It's all very generic stuff.
Old 09-26-2017, 02:45 PM   #25
interstateflyer's Avatar
2017 25' International
Los Osos , California
May be insufficient gas pressure due to low LP level in the tank. Switch to your other tank. Be sure to purge the line by turning on and lighting your gas stove.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-26-2017, 06:09 PM   #26
penrose , Colorado
Circuit board is what I'm thinking. Stove works, furnace works. I have a multi meter but very green at using it. Fuses look to be fine. I'm getting 9.6 volt ( I believe) at the back end of the electrode when LP is called. I'm clueless and honestly can't afford to take to a dealer. The furnace only heats on shore power. Blower works....just doesn't heat
Old 09-27-2017, 09:22 AM   #27
Half a Rivet Short
Hi
One thing that might help - include your trailer information in your personal information. That way people would have a better idea about which set of gear you likely have.
One way to get up to speed on a lot of this kind of stuff is YouTube. There are tons of videos on repairing just about anything on the planet. Always watch at least three or them. You never know when the first one you find makes some sort of stupid mistake until you have seen the other two ...
Old 09-27-2017, 01:08 PM   #28
1979 23' Safari
Wayland , New York
Is this what voltage is supplying the fridge. If so you've likely found your problem. That's not enough to run the fridge.
Fridge won't work on electricity or propane jhenschen Electrical - Systems, Generators, Batteries & Solar 32 07-08-2014 09:24 PM
We won, we won!! Cyberous Friends of Dorothy 37 02-01-2013 10:08 PM
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 09:19 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
I won, I won!!!! till Off Topic Forum 13 11-28-2004 07:17 PM
