Old 02-12-2010, 02:37 PM   #1
2009 25' SS International
Pasadena , California
Fridge won't turn on
25' 2008 CCD... Last nite turned on gas, bleed the line by turning on stove... Today display toggles between 60 and LP...
Please help how can I save my weekend trip?
Thanks!
flmgrip is offline   Reply With Quote
Old 02-12-2010, 03:28 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Cycle power... repeatedly
On the assumption that nothing actually broke, I recommend you cycle power to the refrigerator and try again.
It is very possible that the LPG has not made it to the fridge yet in spite of other gas appliances being run.
Turn power off to the fridge to clear the error message. Turn power on, and do whatever it takes to make it try again. You might get several 'no joy' responses.
Although "hate" is a strong word, I hate appliances that protect me from myself. But I do understand (litigious society) why they are designed that way.
Good luck,
Tom
Old 02-12-2010, 03:39 PM   #3
VIKING's Avatar
Boulder Creek , California
I'm guessing you checked the gas and power first, right?
Next, do you have the manual for it? If so, there should be a section on troubleshooting....
Next, go get a block of ice...
Sorry, that's the extent of my knowledge of newer refers.
If you are going to have hook-ups at your destination it may not be an issue. Have you tried it on 110v power?
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 02-12-2010, 03:42 PM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Ok, Is the switch on LP or Both or 110. Sometimes mine gets switched to just shore power and it won't come on. Just a thought. Just covering all the basics.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 02-13-2010, 04:20 PM   #5
Thanks everyone for their replies...
The bag of ice was the quick fix... Turning on and off about 5 times and it started working... I guess that'll teach me to make sure next time the fridge really turns on...
Thanks again !
won't turn off! AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-22-2009 09:52 AM
Turn The Key And Nothing Happens Chaplain Kent Mechanics Corner - Engines, Transmission & More... 102 04-20-2009 07:02 AM
When to turn on heat??? tmarquis Winterizing, Storage, Carports & Covers 5 03-24-2009 09:40 PM
The PO was going to turn it into a shed! kenthelen Member Introductions 9 07-18-2008 09:57 PM
Fridge Fan won't turn OFF clancy_boy Refrigerators 7 09-04-2007 08:55 PM
