Old 07-31-2010, 08:56 AM   #1
keithwade's Avatar
1965 20' Globetrotter
Winter Haven , Florida
Fridge won't cool on gas
I should probably preface by noting that this 1965 Globetrotter is our FIRST RV, so we're kind of neophytes. Also, I did check the forums, but didn't find exactly this problem.
We have the original 1965 Domestic AC/LP refrigerator. It cools fine on AC... within about 24 hours it is freezing cold. However, on LP it simply does not get cool (have left it on as long as 5 days).
Fridge lights and flame does not go out (as noted, we have let it burn as long as 5 days).
Took it to a repair place. They claimed there were no problems with LP, flue, etc. Basically, they said it was old and things shake loose in transit. They said the ignitor (piece of flint on a long stick with a knob to turn to get a spark) had fallen into the orifice and was keeping it from getting warm enough. Removed this assembly completely (it's much easier to light with a match on the end of a dowel) and it still doesn't get cool. The sheet metal box around the burner is not attached all that well (removed it for the photos from the outside hatch... it is usually in place), but it seems to be surrounding everything fire related. Other than that, nothing seems loose or askew.
I am not sure what the flame is SUPPOSED to look like, so I took some photos. I am not 100% sure my pictures uploaded, so here's a link to them: http://share.shutterfly.com/action/welcome?sid=8CaM3LNuxbsxi The flame pretty much stays like this continuously.
Would appreciate any direction. Sure it's a simple fix, but hate to keep throwing money at at.
MANY thanks.
keithwade is offline   Reply With Quote
Old 07-31-2010, 09:20 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The flame looks good.
Did they remove the frig. during the inspection? If not they had no way to check the flue and that would be my first thing to check.
If the unit is getting cold on electric and the flame is good there has to be something between the flame and the coil in the flue below the point where the electric unit contacts the coil in the flue keeping the heat of the flame from boiling the gas. The gas is being boiled by the electric element so the cooling unit is good you just have to get the heat of the flame to heat the coil.
2004 Excursion 4x4
Old 07-31-2010, 09:41 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The cooling process for the fridge is esentially the same for AC and propane. So if it works on AC the guts are good. The flame for running on gas is pretty small. If it stays on that suggests the burner and propane valve are good. Make sure you give enough time for the fridge to cool. At least 12 hours and possibly 24. But you say it was running on gas for 5 days? I would then suspect the burner assembly and orifice need to be cleaned. You could try blowing it out with compressed air before pulling anything.
how can I get a RV fridge to cool in 100 degrees F? nmeyer Refrigerators 15 07-29-2010 08:10 AM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
Fixed Pilot- Fridge wont cool - PLS HELP!! Elf1 Refrigerators 6 06-26-2009 10:30 PM
carrier v low cool vs high cool rvlover Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-06-2008 08:20 PM
Dometic fridge not so cool kenajen Refrigerators 15 03-30-2006 05:05 AM
