Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 05-23-2013, 01:39 PM   #1
Ahem, yasss ...kaff-kaff
egad's Avatar
1969 27' Overlander
Bloomington , Indiana
Fridge too cold & Freezer door ?
I'm just about finished with Betty's interior re-hab (I'll post pics soon) and I remembered last year the fridge would get too cold and sometimes freeze stuff. Searching this question I saw mention of moving a clamp on the thermocouple to adjust the temperature but don't see one on mine. I suspect the thermocouple is bad but before getting a new one I thought I'd ask. Also, is there a procedure for rewinding the springs on the freezer door? I took it off to get the gunky seal clean and it un-sprong!
Egad!
ps. the pic is obviously sideways...can't seem to rotate properly
egad is offline   Reply With Quote
Old 05-31-2013, 09:27 PM   #2
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
The clamp you're speaking of is a little white plastic clip. I have an extra one from a Dometic fridge if you need it. Just PM me with your address.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 06-05-2013, 07:04 AM   #3
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Don't fix it too good, then you'll be like the rest of complaining the fridge doesn't get cold enough.
Kelvin
KJRitchie is offline   Reply With Quote
Old 06-05-2013, 07:43 AM   #4
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Egad!
I had the spring do the same thing.
I don't have a PDF instruction sheet, but basically you go through a reverse installation, if that makes any sense.
2013 25 FC FB (Twin)
2013 Suburban 2500
https://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 06-05-2013, 07:49 AM   #5
Minneapolis , Minnesota
Our fridge is always cold to - what is the function of the clip - if the sensing unit where bad wouldn't the fridge be warm? Thanks
loons2 is offline   Reply With Quote
Old 06-05-2013, 08:43 AM   #6
Branson , Missouri
The clip holds the sensing unit/wire at its highest point in the refrigerator.
2013 Suburban 2500
2011 23 FC FB
Old 06-05-2013, 09:47 AM   #7
Naples , Florida
When your 'sensing unit', called a thermister goes bad, it depends on how it failed. If it failed in the open position, it will cause the board that operates the cooling unit to run wide open, this creating a potential freezing situation in your fridge section.
If it fails in the closed position, it will do the reverse and essentially turn off the unit causing it to warm up.
The thermister changes it's resistance relative to the internal temp of the fridge and sends that resistance value to the control board, which then either runs the heating section of the cooling unit or shuts it down. There are ways to test your thermister at varying temperatures. Check with your operations manual for details, call the fridge manufacturer tech support line or find a qualified RV tech who is well versed on this subject to do the test.
lewster
