Old 08-30-2006, 07:05 PM   #1
76'Sovereign's Avatar
1976 31' Sovereign
Minneapolis , Minnesota
Fridge safety
hey all,
I was wondering, can you trailer down the road with the fridge running on LP? I know that there is a thermo-sentry that will turn off the fuel if the flame goes out. But is the burner protected from the wind of the road?
76'Sovereign is offline   Reply With Quote
Old 08-30-2006, 07:39 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
That's a giant can of worm that you have opened. The opinion is pretty well split between yes and no. We run our refer under way on LP.
SuEllyn & Brian McCabe
Old 08-30-2006, 07:45 PM   #3
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
I thought I'd seen this can of worms somewhere else. Here it is:
http://www.airforums.com/forum...ridge+run+road
I haven't tried it, but then I don't know if a 46 year old Dometic would stay lit while in motion to begin with! I have seen some postings somewhere about a baffle protecting the burner from wind, however.
Edit: Oh, moosetags, I just realized that was one of your threads.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Aluminocentricity
Sugarfoot is offline   Reply With Quote
Old 08-30-2006, 08:11 PM   #4
1976 31' Sovereign
I think that I will error on the side of safety and just pack a cooler. I don't plan on any cross country trips anytime soon.
Thanks for all the help, this site is a GOLD MINE! Since I have this old/new AS
Old 08-30-2006, 08:18 PM   #5
1973 31' Excella 500
Morristown , Tennessee
Have't taken my new trailer on the road yet. I'm in the process of restore - nothing fancy - just functional. I will travel with the refer lit. I see no reason not to. I had a 25" 1971 model and traveled thousands of miles without a problem. I follow checklists similar to those when flying and this included checking the cold box for problems. None with the old unit and don't expect any with the new coach.
Good luck. You'll do what's comfortable.
Joe
Alumin8 is offline   Reply With Quote
Old 08-30-2006, 08:23 PM   #6
Frank S
peoria , Illinois
Hi 76'Soverign--I always travel with my fridge propane on. It has to be checked from time to time as sometimes the flame blows out. If you don't want to travel with it on, keep it on until you start on the road. Then turn it off, and back on again for extended stops. It may not keep ice frozen, but it will stay cold enough for normal fridge use. Put a thermometer in it (normal fridge temp is 40 Fahrenheit) so you know what the temp is. You can also put ice in a container (milk jug) in your fridge (remember ice boxes of old). Have fun A/Sing.--Frank S
Frank S is offline   Reply With Quote
Old 08-30-2006, 09:06 PM   #7
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, 76'Sovereign,
I only have experience with the Dometic RM-100, but if your Sovereign has that fridge, it's very well baffled and will stay lit during travel. I didn't trust the RM-75 in my '75 enough to run it on propane while traveling, though.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-31-2006, 03:19 PM   #8
draftwomyn21's Avatar
1966 26' Overlander
Phoenix , Arizona
Send a message via Yahoo to draftwomyn21
Fridge Safety
Speaking of Fridges, does anyone know where I can get a new flint for my striker rod (that lighting it from outside and hoping that the wind isn't blowing is a pain in the A_ _, well you know )?
Thanks for the help,
Robin out
"Courage is the hallmark of the warrior"
draftwomyn21 is offline   Reply With Quote
Old 08-31-2006, 04:36 PM   #9
I use LP all the time, but I have a new trailer. One old geezer told me I might want to leave the back end of trailer away from gas pumps when I'm at gas station filling the truck.... but that's one of those err on the side of caution things... I've also parked pretty close, and I'm still here.
Desert Bear
drmmlien is offline   Reply With Quote
Old 08-31-2006, 04:49 PM   #10
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I use an ice chest if need be. My fridge is on all the time, keeping extra beer cold. That way it is pre-cooled for any spur of the moment trips. Usually if drive time is less than 2 hours, its not a problem to leave it off. If we are going on a trip longer than that, we wait and buy perishables at destination.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-31-2006, 07:56 PM   #11
1960 24' Tradewind
santa barbara , California
We travel with our fridge lit .No problem ,ever. Its a dometic rm660 .
this gas station thing is not gonna happen ,blown up trailer,because the vapors are outside in the air .they are not rushing in the trailer when you stop .if you had the trailer inside a gas vapor filled garage with the fridge on
then yes Kaboom ! The vapors have to accumulate inside the trailer enough
to cause an explosion .When your at the pump the breeze is blowing around
and all ,no way the vapors are going to go in the trailer and accumulate as
the vapors are blowing around also.Gas station tanks are vented yards
away from the pumps also and people.I don't think anyone should worry
about it .
Scott
scottanlily is offline   Reply With Quote
Old 09-01-2006, 09:10 AM   #12
Yeah... I think the reasoning was that there is an open flame... right behind the little louvered doors on back of trailer.... and you see all those signs, DO NOT SMOKE... etc. But I don't think it's an issue either.
Desert Bear
Old 09-01-2006, 12:34 PM   #13
Lee Pace's Avatar
Fridge Safety
Robin,
You can buy the Ronson flints at almost all stores.
Good Luck,
Lee Pace
72 Tradewind
Greenville, Tx
WBCCI 7287
Lee Pace is offline   Reply With Quote
Old 09-01-2006, 03:03 PM   #14
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I ran mine on LP on my trip from the east coast to the west. It went out once or twice due to cross winds. I had to check it and re-cycle it several times.
I had no problems. You should turn it off when you fill up the tow vehicle.
Michelle TAC MT-0
Sarah, Snowball
RV safety education foundation 83Excella Link Archive 5 10-15-2004 05:44 PM
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
