Old 01-13-2019, 05:09 PM   #1
TWC
2015 25' International
Georgetown , Ontario
Angry Fridge runs hot
I have a 2015 25' Rear bedroom Serenity. The fridge was recently replaced with a new one. The fridge is vented through the side of the trailer rather than through the roof. An exhaust fan is mounted in side compartment behind the fridge and is thermostat controlled. The fridge generally runs at 39 to 42 degrees even when OAT is below 20 Celcius and the louvered panel is propped open. This seems quite high. What are others experiencing? Any suggestions on how to lower the operating temp of the fridge? Could the thermostat be at fault? Thanks for any help.
TWC is offline   Reply With Quote
Old 01-13-2019, 05:14 PM   #2
2018 28' International
Fayetteville , Georgia
Have you adjusted the temp probe in the refrigerator? From memory, sliding it up lowers the temp.
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 01-13-2019, 05:24 PM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
What setting do you have your fridge set to 1 to 5?
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 01-13-2019, 05:27 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Mine got significantly colder when I slid the temperature probe up to the top of the fin it was mounted on.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 01-13-2019, 05:44 PM   #5
TWC
brick
Where is the temp probe that you refer to?
Old 01-13-2019, 05:46 PM   #6
TWC
Setting it on 5 does not appear to improve the cooling.
Old 01-13-2019, 05:48 PM   #7
TWC
Usually on 4. Setting it on 5 does not seem to improve the cooling.
propane smell when fridge runs on gas. Gearheart Refrigerators 2 06-23-2016 12:34 PM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 02:08 AM
A/C help. It runs hot when it should be cold Aviator General Repair Forum 2 04-04-2012 02:02 PM
Magic Chef Wall Oven - Runs HOT Gael79 Stoves, Ovens & Microwaves 6 09-12-2011 12:27 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
