I have my gas tanks off my as. I tried to turn on the fridge on electric. It waited a couple of secs and threw the chck light.
do my tanks have to be hooked up for my fridge to run on ac power?
No ... propane is not involved if you are using shore power or a generator.
If you want to run on electricity you must be hooked to shore power or a generator.
If the check light went on your frig thought it was supposed to be using propane. It would only come on if you have the frig set for propane usage, or if it detected electricity...and then no propane source.
The reason i posted? ??? Is that i have both tanks off, 110 hooked up and i cut fridge to electric and it waits a couple of secs then ck light comes on. The person i purchased from said he replaced the board in it. I wonder if something is put back togethet wrong for it to b doing this
Obvious question, have you checked to see if you have 110 to the fridge? Is there a fuse somewhere that might be blown? If you have electricity to the fridge and it isn't working, the board might be the problem. Good Luck and let us know how it all works out.
The first thing to do is check to see if the three-pronged 110/120 VAC cord from refrigerator is plugged into the wall outlet in back of the refrigerator. This just happened to me recently when I discovered that neither the factory nor dealer had plugged it in. The fridge had run solely on propane for four years in spite of being hooked to shore power. When I ran out of propane it could not switch to 120 VAC. BTW: the circuit board and front panel run on 12 VDC (battery).
DonS
"It's like magic, only real"
(Bud Light commercial)
Women and cats can do as they please, while men and dogs should relax and get used to the idea.(R. Heinlein)
