Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 09-30-2005, 04:11 AM   #1
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Fridge pilot blowing out
My refrigerator's pilot light now blows out when going down the road. Since the fridge cools great when sitting at a campsite running on gas, I do not think there is anything wrong with the gas supply. Unfortunately, I think my current problem was created by me as I fixed a totally different problem.
In my Airstream, the refrigerator sits next to the oven with a plywood partition between them. Since the oven is shorter than the fridge, it is elevated allowing for pots & pans to be stored beneath. Ever since the Overlander has been back on the road, we have arrived at our destination to find dust covering the pots & pans.
I think this dust had been blowing in through the refigerator's floor vent, and then through a squirrel-sized hole in the plywood partition between the fridge & oven to settle on everything stored beneath the oven. I did not patch the hole during the refurb because I did not think it would hurt anything. But since it appeared to be responsible for the frown on my wife's face, a piece of luan was scabbed over it. With the air's escape route blocked off, I am left to think that it must be swirling around under the fridge a lot more forcefully than it used to, and blowing the pilot out in the process. I checked, and the roof vent is clear.
I shared this dilema with Overlander63 at the Fort Desoto rally (back when he was a regular member, and not the lofty moderator he now is ). (Congrats on the new status, Terry ). He was surprised at how large my floor vent was. Measuring 8-5/8 square inches, the vent was apparently much bigger than the ones he had seen, and he recommended blocking off part of it. Finding that to be an excellent suggestion, I whipped out my trusty roll of Duct Tape, and masked off about a third of the inboard side. No joy. The flame still blew out going down the road even when it was going full tilt.
There are two things I plan to try before leaving on next week's trip to Disney World. The first is add additional 20 gauge, metal baffling around the pilot light. If that does not work, I will try covering more of the floor vent than I did at Fort Desoto.
Does anyone have other suggestions on how to keep the pilot light lit and dishes clean at the same time?
Tom
Old 09-30-2005, 01:09 PM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
The hole should definitely be closed. The area behind the refrigerator should be well sealed from the interior of the trailer to keep CO out. Keep the luan.
Some folks place a furnace filter inside the louvers of an outside refrigerator door; you could do the same over your vent in the floor. The filter allows airflow but has enough restriction to curb the gusts.
If that doesn;t work, some creativity with a tinsnips and some sheet metal may yield a workable baffle.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 09-30-2005, 01:13 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The summer issue of Airstream Life showed a plate that an owner had made to fit inside of the door to prevent the pilot from blowing out. You might want to take a look at that.
Richard
Old 09-30-2005, 07:04 PM   #4
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Looking at TomW's installation at the rally, I was impressed by the rather large hole exposed to the rear in the baffle around the heater flame. I looked at my Excella and my Argosy back at home from the rally, and both are rather tightly baffled, and neither has ever blown out when towing.
Tom, the vent under my Argosy's fridge is every bit as large as your's, and yes it does collect some road dust.
Let us know what solution you find.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 09-30-2005, 07:20 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
When I bought my trailer the PO had regularly travelled with the fridge running. He had both a baffle around the burner, and a furnace filter over the hole in the floor. Apparently this worked quite well. I will have to try this myself, as I was parked at a windy campsite on our last trip, and the wind was enough to blow our pilot out while we were out exploring, causing us to come home to a warm fridge and ruined food!
I have a re-ignitor on the water heater. How come fridges don't come with those? I guess I should look into having one installed.
Stephanie
Old 10-16-2005, 12:20 PM   #6
TomW's Avatar
1967 26' Overlander
Smile Pahaska wins the prize on this one
Originally Posted by Pahaska
... Some folks place a furnace filter inside the louvers of an outside refrigerator door; you could do the same over your vent in the floor. The filter allows airflow but has enough restriction to curb the gusts.
I don't know which of John's suggestions worked because both were implemented for our 1400 mile (round trip) to Disney World from which we have just returned. A 12" X 12" furnace filter was Velcro-ed to the vent, AND a custom trimmed piece of sheet metal was secured to the works with aluminum tape. The pilot remained lit the entire trip.
Number 1 son, in the picture below, shows "Option C" which was not needed - A piece of sheet metal trimmed to fit all but a small portion of the 8-5/8 square inch grate. Thanks John!
Tom
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Ref pilot Dbraw Refrigerators 2 08-27-2002 04:43 PM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
