Old 07-26-2009, 08:13 PM   #15
2007 25' International CCD FB
Newport Beach , California
Having the same problem with our 2007 airstream and would also like to see some pictures of the baffle / shield to see its size and location.
Thanks in advance,
Hank
oceanair is offline   Reply With Quote
Old 07-27-2009, 07:56 AM   #16
I found a picture of the Dometic fix on another thread. Hope this helps. I also found on another thread that dometic makes a kit for this problem.
Hank
Old 08-21-2009, 10:02 AM   #17
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
any older airstream owners,like a 1970 travel with the lp lit while travelling or is it too unsafe in an old one also ? Thanks !!!
Rollerboy is offline   Reply With Quote
Old 09-09-2009, 11:27 PM   #18
2007 25' Classic
Mount Vernon , Washington
I am having this same problem with the refer in our 07 Classic and it is a big problem for us. On the road it does not seem to work because the temps in the unit go from 39 degrees when plugged in to shore power to as high as 60 degrees when traveling a long distance in very hot outside temps. On mild days the temp may go into the upper 40s.
I sent some e-mails to Dometic and they have sent me their part number for the air baffle. It is 3108039.003 "Air Foil Kit" for Dometic 6 and 8 cu ft models.
Also I got some advice from the Air Stream dealer to try a furnace air filter (10" by 20" I think) on the outside air vent. This seems to help but must be removed each night. So next I will try the Air Foil Kit.
Tom
tomlong10 is offline   Reply With Quote
Dometic fridge doesn't stay cold when travelling Work2play Refrigerators 9 06-23-2009 07:15 PM
What keeps fridge cold while travelling? ole81 Batteries, Univolts, Converters & Inverters 14 07-29-2007 09:13 AM
Travelling with Motorcycle ScottMac Towing, Tow Vehicles & Hitches 24 10-28-2006 01:32 PM
fridge on when travelling? sjptak Refrigerators 2 06-16-2003 09:54 PM
