Old 06-27-2008, 08:24 AM   #1
Fridge just Kicked.
I have a 1966 Globetrotter that has the original refrigerator. The thing just craped out on me. I have always had it hooked up to AC. Worked fine since I have had it. Now it does not get cold. I was wondering where to start before I tear the thing apart. It does get power so its not a power issue. I like the way the original fits and looks. I really want to try to save it. Any tips would be great. Thanks!!!!
nbka1bm is offline   Reply With Quote
Old 06-27-2008, 08:31 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It could be the heating element is open. You could check it with a multi meter.
Does it work on propane?
Richard
Old 06-27-2008, 08:34 AM   #3
have not tried it on propane. waiting on my plumber to replace all of the propane lines. I can't rush the plumber since he is doing all the work for free. He just redid all my water lines and said he would be back in July to go the gas.
Old 06-27-2008, 08:50 AM   #4
2002 25' Safari
Dewey , Arizona
Images: 62
Never rush anyone who works at that hourly rate!
Richard
Old 06-27-2008, 08:51 AM   #5
no doubt. The only thing that the water pipes cost me was 20 bucks for some fittings he did not have on the truck. All new pex lines and a new WH. Pex is the way to go in my opinion.
Old 06-27-2008, 10:12 AM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
As mentioned above test the element.
Remove one side of the wiring to the element. Now with the AC on test across the wires coming to the element for 110 volts. If that is Good. disconnect the AC and with an ohm meter test the wires going into the element. If you do not get a reading there the element is open. If you did not get 110 when testing for it the board may be bad or power may not be getting to the board. Test the input to the board for 110.
2004 Excursion 4x4
Kicked out of a campground Blu_Hwy_Lady On The Road... 188 03-16-2011 12:04 AM
Fridge help! Minnie's Mate Refrigerators 3 10-26-2007 02:04 PM
Wow, thought I had been "kicked out" :) Kistler Forum Admin, News and Member Account Info 4 08-26-2006 06:13 PM
Been Kicked in the Astrodome Jeffrey Stoecker Roof Vents, Skylights & Fans 1 04-19-2006 08:31 PM
LP Gas smell when furnace first kicked on Impala SS Guy Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-30-2003 12:08 PM
