Old 08-19-2015, 09:37 PM   #15
2011 19' Flying Cloud
Renton , Washington
It was a 12v fuse. Fridge working again! Still don't know what's up with ac but at least we have fridge for the weekend. I'm guessing I need to replace gfci curcuit breaker before add'l troubleshooting there. Thank you for the assistance!
orange kayak is offline   Reply With Quote
Old 08-20-2015, 07:12 AM   #16
richw46's Avatar
Lexington , Kentucky
On the frustration issue, been there too. My wife heads for the hills when she sees that slow boil starting to show up on my face.
Diagnosing issues is a matter of elimination. If the fridge isn't working on AC you need to know if it's in the fridge or the wiring. If you have an extension cord, plug the fridge into that, then the cord into the 15 amp plug on your power post next to the 30 amp (or any known working outlet). Make sure the power post breaker is "on". If the fridge is running, you know it's the wiring. If not, it's the heating element inside that tube near the chimney.
Mine went bad but it's easy to replace. Remove the one screw on the access flap and remove the flap. The heating element is right inside; remove and replace.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-20-2015, 09:33 AM   #17
Renton , Washington
You are so helpful! Thank you. I'll test the fridge AC w/ extension cord tonight.
Old 08-20-2015, 09:47 AM   #18
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Regardless of either propane or electric power for the fridge, the 12Vdc is needed to run the logic board in refrigerator.
Old 08-29-2015, 12:57 PM   #19
Renton , Washington
Finally got a chance to test fridge. Works fine when on gas. Turned off gas, plugged fridge directly in to extension cord plugged in to outlet. Still get the clicking sound like it's trying to start but wont.
GFCI breaker won't reset. Either related to fridge or something I did trying to troubleshoot. Can I replace it (esentially, is this a job a novice can handle?) Still camping season here; I'd prefer not to haul in for service if it's still safe to use. : )
Old 08-29-2015, 01:18 PM   #20
Renton , Washington
I did try to remove screw holding flap by chimney. Was pretty tight and I didn't want to strip it out. I'll see if service can do a quick turnover.
Old 08-29-2015, 05:00 PM   #21
richw46's Avatar
Counter-clockwise on the screw, then the chimney flap can be removed. Unplug the electric heating unit, you will need to find another one because it sounds like that one is broken so the fridge just stays on gas, it can't detect the electric unit being there or it's shorted out and keeps the breaker from resetting. As I recall, mine just slid down, I don't recall anything holding it down. It just plugged into the circuit board.
My trailer's in storage right now or I'd go check it out and send a picture.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 10-08-2015, 05:04 PM   #22
Renton , Washington
Update
Ok. There is an update.
Because the fridge worked on gas, and I felt I'd made the problem worse, I decided to take it to the local Airstream dealer when it was convenient which ended up being a couple weeks ago. I'd practically forgotten the details of the issue. (Lesson for me here--go in sooner or write it all down)
I had previously tried plugging fridge in to another outlet via extension cord and it still went through the cycle of trying to ignite. So I thought I had isolated the problem to the fridge and relayed that info to the dealer.
As always happens (to me, anyway) with things mechanical, they were able to reset the GFCI breaker with no problem (I couldn't get it to reset) and the fridge worked for them on electricity.
What didn't 'click' for me, while we were walking through after repair, was that the gas was on.
Driving home, I remembered that the fridge HADN'T worked for me when plugged in to a different outlet. And the gas had been on at the dealership. When I got home I plugged in, made sure gas was off, and turned fridge on to AUTO. And the clicking began. I left when the CHECK light came on.
BUT! I also left it plugged in and put an ice cube tray full of water in the freezer. A few hours later I rechecked the fridge; the CHECK light was off and I had ice.
I've had the fridge plugged in, gas off, for several days now. I still have ice.
The service manager is going to check with the technician who worked on the trailer and get back to me. I'll post again with whatever I learn.
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
fridge issue solved just an easy fyi Bex General Appliance Topics 1 08-17-2014 09:04 PM
Dometic Fridge issue vicn2000 Airstream Trailer Forums 1 05-02-2012 10:15 AM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
