Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 08-18-2003, 10:28 AM   #1
tjj's63's Avatar
Profile:  1963 28' Ambassador
Orange , California
fridge is not working!
just bought and hauled our airstream home this weekend & i have all sorts of ?'s. i have a 63 ambassador with the original fridge in it and it doesn't work- does anyone have tips?
tjj's63 is offline   Reply With Quote
Old 08-18-2003, 11:24 AM   #2
mkeith54's Avatar
Profile:  1976 26' Argosy 26
New Florence , Missouri
Send a message via AIM to mkeith54 Send a message via Yahoo to mkeith54
When you say it is not working, which mode is not working. Have you lit the pilot light? For that matter did you pull a me and not have enough LP? My pilot would light but then go out when the burnner kicked in because the LP was low. Is the trailer totally level side to side and fore to aft? The older units are very finicky about this.
If you are running on electric check the fuses and ohm out the heater element.
Another thing to look for is green corrosion, the green comes from the amoninia leaking out. This is youmight surmise is not a good thing. If it has leaked you might be able to replace the cooling unit , but you may have to replace the entire unit.
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
WBCCI 4503
Gr8r STL Unit
mkeith54 is offline   Reply With Quote
Old 08-18-2003, 11:37 AM   #3
tjj's63's Avatar
Orange , California
i am going on what the previous owner said- he also said to maybe pull it out and flip it upside down (which i heard was a bad thing to do). to be honest, i haven't tried any propane related start ups- i'm a little nervous! i need an owners manual, too! i guess this is welcome to the world of airstream ownership, right?
Old 08-18-2003, 11:47 AM   #4
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
It is best to try it in AC mode first since this doesn't require the burner. Set the thermostat to maximum cold. After you turn it on, wait an hour and then open the lower outside access door and feel the shroud around the boiler (looks like a piece of stovepipe). It should be warm to the touch if the element is working; the tube coming out the top of the boiler shroud should be getting hot by this time. If no heat, then either no AC to the refrigerator or a bad heating element.
In summer weather, it takes a while to cool down. After 2 hours, the freezer compartment should be getting pretty cool. It will take up to 3 or more hours before the refrigerator part is noticeably cooling. By overnight, the refrigerator should be getting down to temperature.
If the boiler is getting hot and the refrigerator is not cooling by this time, the cooling system is shot and it is time for a new refrigerator or a rebuild.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 08-18-2003, 12:11 PM   #5
drboyd's Avatar
Profile:
Actually, the "turn it upside-down" method is mentioned in the Dometic service manual, believe it or not.
http://www.bryantrv.com/docs2/docs/rmX60.pdf page 10
Old vs. new gas fridge performance mcneon Refrigerators 8 01-26-2004 07:47 AM
what should I do with my dead fridge Swingking Refrigerators 12 11-25-2003 02:45 PM
First pipes now fridge... overlander76 Refrigerators 8 11-24-2003 02:46 PM
Got my fridge repaired Stefrobrts Refrigerators 2 10-31-2003 01:12 AM
Dometic 3800 fridge is not working swebster Mechanics Corner - Engines, Transmission & More... 6 08-08-2003 10:20 AM
