Old 01-01-2011, 03:48 PM   #1
Sailor-d's Avatar
2012 22' FB Sport
Chemainus, Vancouver Island , British Columbia
Fridge in 17' Safari Sport
I am acquiring the 17' Safari this spring at a location in Ontario. I think the fridge runs on 110V. I know it works on propane - mainly I want to know if it runs/cools on 12V while underway on the highway.
Cheers - Dave
Sailor-d is offline   Reply With Quote
Old 01-01-2011, 04:34 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
That depends on the model. All RV fridges are NOT 3-way units. Most are 2-way: 120VAC when present or LP. If you do have a 12VDC heating element present in your unit, be advised that they will NOT cool down the fridge, but rather are designed only to MAINTAIN the temps inside while traveling. Also be advised that for every minute that you leave the fridge door open, it requires ONE HOUR of fridge operation to recover the lost internal temperature.
Old 01-01-2011, 05:51 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The fridge in the Sport models we've sold at the shop are strictly 2 way (120 volt and LP), no 12 volt cooling. These were 2008 models of both the 17 and 22 foot flavors.
Old 01-01-2011, 06:12 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Ice
While traveling the best ways to keep food cold is
  • have your refrigerator/freezer FULL of cold food - put it in a day ahead if necessary. Leave space for a bag of ice and put one in just before leaving. You might double bag it to prevent leaking as it melts.
  • Leave the reefer door closed as much as is humanly practicable.
  • If you stop for a meal, nap, etc. during the hot part of the day, open the roof vents of the airstream to get rid of excess heat buildup inside - the fridge stays cooler if the A/S isn't 120 F inside
  • Carry a thermos or small cooler with water/soda in the tow vehicle so you have something to drink without opening the reefer
  • on really long hauls, when you stop to rest, turn the fridge on GAS,
  • older models, the gas fridge light tends to blow out while traveling, and it could be dangerous around fuel pumps... newer ones will relight. While many people do use gas while traveling successfully I don't see that it's necessary... or smart.
  • Of course if you're going somewhere ON the grid, you can easily stop and get groceries when you ARRIVE rather than when you leave.
In the TINY streams like yours, you can't carry that many groceries anyway, and the "bag of ice" could easily be a couple of trays full. Remember many vintage units were literally Iceboxes - You put a big block of ice in, and it melted out through a drain hose.
