Old 06-03-2011, 06:44 AM   #1
2008 27' International CCD FB
Visalia , California
Fridge help
We bought a 2009 27FB International last Nov., all seems to be great. We left Calif. the last week of May for North Carolina, the fridge worked fine when the unit is parked on gas or electric--when on the road and set on auto, the gas light comes on but the fridge does not maintain the cold temp--goes from 37 the start of the day to 50 by the time we park it for the day. Any ideas as to what I should do??
Chuck
ThreeFingers is offline   Reply With Quote
Old 06-03-2011, 07:12 AM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Greetings, Chuck, and welcome to the forums!
Did you park your Airstream in a nice, level spot? We've found that the newer refrigerator in our vintage rig is much more sensitive to level than our old, dearly-departed one.
Lynn
WBCCI 21043
Old 06-03-2011, 07:17 AM   #3
It works fine when parked, it was on the road driving in 100 degree weather that it would not keep cold, as soon as we parked it worked fine on gas and electric
Old 06-03-2011, 07:21 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Open the freezer door, there should be two switches inside the top edge right side, make sure they are both off.
A small battery powered circulation fan inside the fridge section helps too. Inspect seals both doors.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-03-2011, 07:21 AM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Ah, ok! Are you sure that it was actually running while underway? Sometimes those fridges need a baffle of sorts to prevent winds from blowing out the little flame. I'm sure some of the others will jump in with more details on this.
Lynn
WBCCI 21043
Old 06-03-2011, 07:33 AM   #6
The seals all look good, I can not find two switches, only the controls switch on/off -- control auto, gas -- and temp.
Old 06-03-2011, 07:44 AM   #7
On our 03 Classic they are inside, on the left upper edge of the freezer door opening, one will keep the light on when the door is closed to raise fridge temp when camping in cold weather. The other, I haven't figured out yet.
PFC
RLC
Old 06-03-2011, 07:57 AM   #8
dznf0g's Avatar
Oswego , Illinois
The other one heats up the area between the freezer door and the fridge door to reduce condensation from forming in that area during high humidity times.
Old 06-03-2011, 07:58 AM   #9
This fridge/freezer does not have a door switch or light in the freezer
Old 06-03-2011, 08:06 AM   #10
Must be a different model....our light in main compartment stayed on all the time when we took delivery, took awhile to figure out what that one switch did, dealer didn't know either...
PFC
RLC
Old 06-03-2011, 08:06 AM   #11
aftermath's Avatar
Spokane , Washington
Open the refrigerator door and look up at the frame, just below the freezer door. Mine is mounted horizontally and points down. It is a black toggle switch that helps mediate frosting by heating the back side of the compartment. I seldom use it and never turn it on when I am boondocking.
I would be surprised if your original unit does not have this switch. Keep looking, lay on the floor if necessary and look up. It is sort of a stealth switch not meant to been seen by the regular crowd. Must be Airstream's version of the secret handshake.
aftermath is offline   Reply With Quote
Old 06-03-2011, 08:28 AM   #12
I looked again, our frig is a Dometic frig/freezer and is two years old, no other switches in view other than the three that controls the unit;
Old 06-03-2011, 09:43 AM   #13
Wise Elder
Jammer's Avatar
2010 30' Classic
Lynn
+1. If the flame blows out more than a couple of times the controls won't try to restart it for an extended period (an hour or so, I think). Sometimes it's because of high crosswinds and there's nothing you can do about it. In some cases, it's possible to fashion a baffle or windscreen of some kind to protect the burner from wind while still allowing combustion air to enter.
Old 06-04-2011, 06:51 AM   #14
Thanks for your reply, I ran the unit all day yesterday (we are parked) on gas and it worked perfect. Any ideas on a baffle?? I was thinking some heavy duty foil on the bottom half of the air intake vents on the cover door.
Anyone need fridge parts from old Dometic '76 sweetsilver Refrigerators 4 06-24-2011 09:41 PM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Skip the Fridge? (Overlander Newbie) pyrenees Refrigerators 15 05-09-2011 05:30 PM
'71 Dometic fridge question 386kustoms Refrigerators 1 04-16-2011 07:47 AM
wanting to sell my 1959 Norcold 2 way fridge cindy Refrigerators 4 02-26-2011 10:17 AM
