04-16-2011, 06:39 PM
2005 28' Safari
saline
, Michigan
Fridge going out on the highway
I noticed our refridgerator does not keep running while on the highway. When we stop for a break, I check it and sure enough it is out. I re-start per the instructions and it starts up again fine. Next rest stop, out again. I suspect the flame is going out on the highway. Any suggestions?
04-16-2011, 06:47 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Some people use furnace filter material cut to fit inside the access door vent. This seems to stop some of the breeze from coming in and blowing out the pilot flame.
04-16-2011, 07:04 PM
More than one rivet loose
Los Alamos
, New Mexico
Are you affected by the Dometic recall? If so that will fix it. If not a baffle around the burner tube works.
Michelle TAC MT-0
Sarah, Snowball
04-16-2011, 08:13 PM
1966 22' Safari
Hilltop Lakes
Any pictures or drawings of that baffle?
Our fridge does this too.
Does anyone have a picture of the baffle that goes around the burner tube or a drawing of how to build one?
04-16-2011, 11:27 PM
2007 19' Bambi
2005 18' Westphalia
Evans
, GA
We had an 04 CCD with the same problem.
We purchased a stove vent filter that was a perfect fit.
My husband fabricated a latch to hold it in place.
It worked perfectly and did not seem to cause any problems.
04-16-2011, 11:40 PM
Trabuco Canyon
I think this would be good place to start. Most '05s are probably affected by the recall. Has it been done on yours?
04-17-2011, 06:19 AM
2005 28' Safari
saline
, Michigan
I didn't know there was a recall. I will contact Dometic. It looks like the baffle is the fix and I think that can be easily fabricated in my shop. Many thanks,
John
04-17-2011, 06:42 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
My refer was not part of the recall, but my local SOB dealer, (a good guy whom I wished sold AS!) gave me the retro fit kit supplied by dometic. He said he gets them by the case free. I looked the install procedure, but decided to use aluminum foil tape used by heat and air folks. I just covered the burner housing and closed a few cracks. Worked well.
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
04-17-2011, 06:46 AM
2007 31' Classic
Pulaski
, Tennessee
In my previous trailer I had a dometic regrig. It was not relighting when the flame was blown out by passing trucks. Unfortunately it was not covered by the recall but I replaced the board and didn't experience any problems after that. I would recomend you check to see if yours is covered by the recall. The link is here: Official Dometic Recall - DometicUSA
If it isn't covered, you might replace the board anyway. You shouldn't have to put in special coverings if the refrigerator is working properly.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
04-17-2011, 08:52 AM
Los Alamos
, New Mexico
Mine has been done and my baffle is gone. It does not go out on the highway.
Michelle TAC MT-0
Sarah, Snowball
04-17-2011, 09:06 AM
2005 19' Safari
GLENDALE
, AZ
Jdalrymple, do you have photos of your modifications?
07-05-2011, 09:38 AM
2007 27' Safari FB SE
Wheat Ridge
Fridge doesn't work while driving
I have a 2007 Safari FB and the refridgerator does not stay cool when driving. It works wonderfully when parked. We have had this problem since we purchased it 4 years ago. The dealer installed a "wall" inside under the theory that it would prevent the wind from blowing out the flame. Well, that doesn' work, recently it was 54 degrees after a 6 hour drive. is there a way to fix this permanently. I have had RV's where the refer stays extremely cold in all travel situations. And this is very frustrating. we have reverted to carrying ice chests to keep the food (and beverages) cold. Where could I get a "stove vent filter?
07-05-2011, 12:11 PM
Springfield
, Virginia
Domestic makes a kit to prevent the pilot light from going out when moving. I had the kit installed while having repairs at JC. Fridge works great now.
07-05-2011, 12:24 PM
Holly Lake Ranch
Has anyone done the installation of the Dometic recall baffle themselves? I have one under the couch that I guess the PO got but never had installed.
07-05-2011, 12:48 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
The "wall" that Driver mentions sounds like the baffle in the Dometic recall. Perhaps it was installed incorrectly. We have it—by the time ours was produced, the baffle was standard and it looks like a piece of galvanized steel bolted to the back in front of the heating units.
Gene
08-01-2013, 09:18 PM
2007 25' Safari FB SE
Eugene
, Oregon
How much did the baffle kit cost?
08-01-2013, 09:22 PM
Eugene
, Oregon
Our 2007 Dometic has the sheet metal guard installed around the burner but we still have trouble with blow out by passing trucks and wind gusts while travelling. I've heard of a baffle kit installed on the door backside but I think I'll try a cheap air filter first.
08-02-2013, 03:52 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Over at the "Sprinter and B-vans" forum, this subject came up, and the recommendation was strongly against installing an air filter in place of a baffle. The filter can contribute to overheating because it restricts airflow.
08-02-2013, 06:43 AM
i am surprised that fridges work while driving.
Even if the pilot stays lit. I am not 100% sure how they work, but if they need to be level for proper air ( heat ) flow.....the wind must wreak havoc. I usually put a frozen jug of water in the fridge to keep things cool.
