Old 11-22-2009, 10:43 AM   #1
2017 25' International
Durham , North Carolina
fridge gasket moldy--how to clean??
'06 Bambi CCD
new to me!!!
but fridge gasket is moldy.
what is best way to clean it?
what to use......and what NOT to use.
thanks!!
WanderStream is offline   Reply With Quote
Old 11-22-2009, 11:40 AM   #2
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
gasket
You have a couple of choices. I have an older refrig. and I use Clorox Cleanup with water. If you prefer you can go green with vinegar and water. Both should get rid of mold. If you find a stubborn spot use a little Comet, but don't mix that with bleach!!
Lou
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 11-22-2009, 11:45 AM   #3
ASwifey's Avatar
2010 30' Flying Cloud
Bakersfield , California
I second the Clorox Cleanup with Bleach. I spray it on, let it sit for a few, then use a gentle brush.
We also leave or fridge doors open a little when the trailer is not in use to prevent mold growth.
ASwifey is offline   Reply With Quote
Old 11-22-2009, 11:46 AM   #4
1977 31' Excella 500
plano , Texas
Mr Clean magic eraser... It did wonders on mine when other cleaners didn't touch it. Mine had about 30 more years of dirt on it.
tschat is offline   Reply With Quote
Old 11-22-2009, 11:51 AM   #5
loudruff's Avatar
1989 29' Excella
toothbrush
I use a soft toothbrush or vegetable brush. And I second the leaving the doors open when not in use. It lets it breath and it doesn't get smelly!
Larry and Lou
Air #2695
TAC- OH 2
Old 11-22-2009, 01:24 PM   #6
frig gasket
thanks to everyone for suggestions!!
i really appreciate your help.
we have just purchased our 1st Airstream & are going thru the learning curve slowly but surely.
susanne
Old 11-22-2009, 07:16 PM   #7
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
I use Clorox cleanup on the gasket, wash out the interior with baking soda and leave an open dish of ground coffee inside....does wonders for any smell that might get in there. But I have also found a new use for the "door thingy"--you know, that thing that keeps your trailer door closed while you are traveling-- it hangs from the top of the door and keeps it open while we're not using it. Whatever you do, don't forget to empty the tray under the freezer when you turn it off, and it defrosts...or you will have a mold (and rust) problem you won't believe. Don't ask me how I know.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
http://chaosinature.blogspot.com/
Isadora is offline   Reply With Quote
Wet and moldy under bed - already halobender 2002 - 2005 International 21 12-04-2011 08:37 PM
'63 Door Gasket dieseleagle Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-16-2009 05:04 AM
Which door does gasket go on? 63air Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 05-18-2009 12:02 PM
Moldy freezer seal 63air Refrigerators 2 03-22-2007 09:57 PM
refrigerator gasket n2916s Refrigerators 0 04-15-2006 12:06 PM
