Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 07-23-2007, 07:51 PM   #1
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Fridge Fan won't turn OFF
I've got an annoying issue with my fridge fan (besides being NOISY). When I park it at home, I ususlly turn off the fridge and crack it open to air dry and keep mold from forming. Well, the last two times I did this the fan continues to run - for days. The unit is turned off, I have the battery disconnect switch thrown to the off position to keep the battery from draining. but I do plug in the 30 amp cord to run the AC if I'm inside (which is every day sometimes.... )
Well, the fan runs and runs - for ever, then stops on its own..... It's running now......
WHY??????
Mike
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
clancy_boy is online now   Reply With Quote
Old 07-23-2007, 08:22 PM   #2
Tim A.
Profile:  2002 19' Bambi
Lafayette , California
There was a thread a while back about some things you can do about the fan noise. You might check that out. As for why it keeps running, well, the fan is controlled by a thermal switch which might be switching on at too low a temperature. Your summer temperatures may be adequate to cause that because the switch measures the temperature outside of the refrigerator. I believe it should only run when you are connected to shore power or have the battery not shut off because it is on the trailer's 12V system.
Before finding another solution, we put a switch in the line between the thermal switch and the fan in order to stop our Bambi's fan from doing what you are describing. That only happened for us on very hot summer days.
Tim A. is offline   Reply With Quote
Old 07-23-2007, 08:33 PM   #3
bobkelly
bobkelly's Avatar
Whittier, California , Depoe Bay, Oregon
Mike---I've got the same trailer as you, 2003 22ft CCD and it does the same thing. I don't have a solution yet.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is online now   Reply With Quote
Old 07-23-2007, 10:42 PM   #4
SilverRanger
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
The 2005 Bambi came with a lighted fan switch mounted to the left just inside the door, on the refrigerator compartment. If it's too noisy at night, sometimes we just shut it off. Ours ran a lot too. Recently, when we took it back for some warranty work, the lighted switch was on the list of repairs. When checking the lighted switch, they discovered the thermal switch was also defective and replaced it, and it does not run quite as much now. I've noticed that when the outdoor temperature is above about 75 degrees, the fan runs constantly.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WBCCI# 4582
WDCU
SilverRanger is offline   Reply With Quote
Old 07-24-2007, 04:40 AM   #5
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Hi Gang,
The fridge fan and the thermal sensor that Airstream uses are IMHO a total POS!
The best fix for this is the fan kit that you can get from Snyder's Refrigeration (rv_cool) on the Forums. It has a proper temp sensor put where it does the most good and the fan and shroud actually work to keep your fridge sooooo cooold!
I've installed a few of these and they work great....and the fan is WAY quieter too!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-24-2007, 07:51 AM   #6
clancy_boy
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
Thank You...
Thank You all that responded. I thought I had a failure in a sensor and was beginning to worry I would burn things up. It's off today so I'm happy.
Lew, I will look into that kit as soon as I return from DC this week. I would like a quieter fan. My fridge runs a little hot so maybe that will help some.
Mike
Michael and Tina BZ
1966 17' CARAVEL
WBCCI 30962
Old 07-24-2007, 08:21 AM   #7
Antique Pedaler
Antique Pedaler's Avatar
Profile:
The quick fix is to unplug the wire to the sensor. Won't hurt anything. Then plug it back in on hot days.
Antique Pedaler
'07 Safari 23 LS SE
'05 GMC Pickup
X '99 Safari 27, X '05 CCD Bambi '19
Santana, and Ventana Tandem bicycles
Antique Pedaler is offline   Reply With Quote
Old 09-04-2007, 08:55 PM   #8
grantb4
grantb4's Avatar
Profile:  2005 22' Safari
San Juan Capistrano , California
There are some pics of the newer trailers here:
http://www.airforums.com/forums/f425...ork-35040.html
grantb4 is offline   Reply With Quote
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 06:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 06:29 AM
