Old 09-30-2005, 07:07 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Fridge door too big
I have a problem with my fridge door. It's too big. The sides of the plastic shelves in the door actually rub on the sides of the box when the door is shut. This keeps the door from sealing tight, thus causing lots of frost inside on the cooling part. We tried wacking with a hammer & board to straighten it out, but the sides actually seem to be bulging. It seems like the door expanded when it got wet or maybe it was filled with too much insulation? My question is this....Can it be fixed? It doesn't look as if the door can come apart without being destroyed. If not, where is a good place to look for a used door for a -'76 excella? If there isn't anyplace, where is a good place to look for a new door for a '76 excella? Thanks in advance to all the Airstream geniuses!
Becky
Becky B. is offline   Reply With Quote
Old 09-30-2005, 08:48 PM   #2
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
swollen fridge door
Hi Becky, our fridge did the same thing and I found out the trick is to keep it closed all the time or it would re-swell.
72 tradewind is offline   Reply With Quote
Old 09-30-2005, 09:05 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
How did you get it to un-swell?
First Big job.updating toilet from chemi to real rheadhuntress Sinks, Showers & Toilets 2 04-19-2004 06:08 PM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
