Old 08-26-2008, 12:23 PM   #1
1976 31' Sovereign
Blairsville , Georgia
Fridge door question
In my previous post I said the fridge was working well...........but I went out to look just now and found that the freezer door is not shutting all the way causing frost and ice to build up at the opening. The plastic interior part of the door contacts the fridge before the door gasket does. It's as though the door's inner plastic panel has warped or swolen. I can't even force it to shut all the way and the gasket doesn't contact the door frame. Anyone know of a fix short of a new door which I can't afford?
Chip Arnold is offline   Reply With Quote
Old 08-26-2008, 01:23 PM   #2
You can relocate the door some what by bending the hinges.
That might help to solve your door problem.
Usually what causes that problem, is ice built up within the door, and expanded it out of shape. When that happens, the warped door will not return to it's original shape.
Rarely, can a door be taken apart and fixed, but it sometimes can be done.
You might seek the help of an experienced service center.
Dometic Fridge door. Antique Pedaler Refrigerators 3 08-04-2008 11:32 PM
Repairing fridge door Zeppelinium Refrigerators 7 06-11-2006 08:51 PM
Fridge door too big Becky B. Refrigerators 2 09-30-2005 09:05 PM
Vintage Fridge door jlawrence Refrigerators 2 06-28-2004 06:20 AM
Anyone have a fridge door? Marko69AS Refrigerators 6 07-15-2003 05:19 AM
