Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 05-31-2007, 09:34 PM   #1
pamelake
pamelake's Avatar
Profile:  1974 25' Tradewind
Lake Oswego , Oregon
Fridge door panel replacement... how to?
We are making replacement panels for my Dometic model RM2801. I bought it without the panels so I don't know how they were placed in the doors.
The metal strip around the door has a small indentation all of the way around. I am not sure if the panels fit into this and get glued into place... or do they slip all the way behing the whole metal strip? I will try to add a picture.
Name:	Fridge panel.jpg
pamelake is offline   Reply With Quote
Old 05-31-2007, 09:50 PM   #2
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Take the top frame off and slide the panel down.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-31-2007, 09:58 PM   #3
pamelake
pamelake's Avatar
The frame is one continous piece... I thought of that but it is not removeable as far as I can tell... Is the panel made to slide behind the whole frame piece?
Old 06-01-2007, 05:23 AM   #4
steelbird312
steelbird312's Avatar
Profile:  1989 29' Excella
Griffin , Georgia
Images: 11
Either the top or bottom of the frame is removeable-all I have ever seen was on the top edge of the frame for both the freezer portion as well as the fridge portion. Look it over closely.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 06-01-2007, 08:51 AM   #5
Excella CM
Excella CM's Avatar
Venice , California
Mine has a flat trim panel-one that goes across the top of the bottom door and one that goes across the bottom of the top door. When those are removed, either panel can be changed. Your photo doesn't seem to show an opening in the frame.
Old 06-01-2007, 09:18 AM   #6
pamelake
pamelake's Avatar
That's my problem... the frame does not open... I am sure there is an easy solution! I just can't see it...
Old 06-01-2007, 09:24 AM   #7
85EXCELLA32
85EXCELLA32's Avatar
Profile:  1986 32' Excella
Crestline , Ohio
There is a trim part that should be inside your refg. one for top and bottom door it will screw into the metal trim around each door.
Jerry
On the River
85EXCELLA32 is offline   Reply With Quote
Old 06-01-2007, 09:50 AM   #8
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Here is a link to the parts catalog for your unit;
RM2801 Parts
It shows a decoration strip on both doors. One on the bottom of the top door and one on the top of the bottom door. Can you find / remove those?
Richard
Charter Member Four Corners Unit
Old 06-01-2007, 10:52 AM   #9
pamelake
pamelake's Avatar
Thanks for your help! That is the problem... I got the fridge without the decorative trim. It looks like I might be able to order them. I have no idea how old this fridge is. The PO of my Tradewind threw it in with the deal, because the original fridge was broken. This one works fine, I just know nothing about it. This has been very helpful and thanks again. Pam
Old 06-01-2007, 11:00 AM   #10
Excella CM
Excella CM's Avatar
Venice , California
Not a big problem. You can purchase flat aluminum strips from a hardware store to replace the missing pieces. Trim panels can be just about anything. Ifr you sue something really thin you may want to make a backing of melamine or sheet steel or aluminum. Best go take a look at a similar refer unit to see how it goes together. From time to time peoploe part out older units and you might get someone to give you the trim pieces.
Water heater replacement Craig Water Heaters, Filters & Pumps 35 06-18-2007 06:47 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
