Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 04-09-2003, 04:30 PM   #1
jwaldin
Profile:
Fridge doesn't work on ac
I have a 72 31' Sov. The propane fridge works fine but when I turn off the propne and switch on the ac or maybe its the dc and then plug the ac cord into the ac outlet nothing happens. The ac recepacle works for other things. I see a white power line coming out of a small box. It is about 18' long and has a two slotted female recpacle at the end but I cann't find anywhere for it to plug into. Any help is greatly appreciated.
jwaldin is offline   Reply With Quote
Old 04-09-2003, 05:06 PM   #2
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
I guess you have a 2 way fridge, propane and 120 volts ac? Good thing it works on propane so you know the major expensive parts are functioning. As far as the 120 volt portion the first thing I would check is the heater. It will have 2 wires going to it and it is located close to the burner assembly, usually right above it somewhat encased in the metal and insulating wrap. Looks like a big glowplug. Get to the wire connection pull it apart and check the heater for continuity. My guess is it will be open, no continuity. Other than that there could be a problem with the cams and levers at the end of the changeover knob and shaft which actually energize the heater or the electric thermostat. The white cord which goes to nowhere could have been the feed for the heater, look into the burner flue and see if you see the heater, they slide into a ring welded onto the burner/coil assembly.
Chas
Chas is offline   Reply With Quote
Old 04-09-2003, 06:10 PM   #3
femuse
Profile:
When you say " ... plug the ac cord into the ac outlet nothing happen" are you talking about the double outlet in the back of the fridge ? the one where the fridge itself is pluged-in?
Other thing: On our 1974 original fridge, we had a plastic cover over the terminal block, with a diagram inside the cover. Check if it is somewhere in the back of the fridge.
femuse is offline   Reply With Quote
Old 04-09-2003, 07:58 PM   #4
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Frige doesn't work on A/C
Try this, Happened to me--- Clean the terminals of the Plug and the Outlet. It's been there a long time. Tom
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 04-10-2003, 07:13 AM   #5
jwaldin
Profile:
Thanks for the info re my fridge. I'll let you know how I make out
Old 04-10-2003, 10:38 AM   #6
pepper48
Profile:  1972 25' Tradewind
Rogers , Arkansas
On my 1972 Tradewind there is a toggle switch that must be changed to go from propane to electric. In order to throw the switch, the propane valve must be shut off. This is a safety switch so that someone doesn't mistakenly try to run the appliance on both propane and electricity.
pepper48 is offline   Reply With Quote
Let's start with the Fridge.... GT1963 Refrigerators 6 03-03-2004 09:01 PM
AC Gasket replacement Sneakinup Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-30-2003 09:07 AM
First pipes now fridge... overlander76 Refrigerators 8 11-24-2003 01:46 PM
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-02-2002 02:04 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
