Old 09-19-2006, 08:29 AM   #1
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Fridg acting up
Fridg question:
I have a 2 year old Domatic which after a few weeks of operation starts to warm up.
Electric/gas makes no difference; on the coldest setting it stays about 40 degrees.
If however, I turn the power switch off for a few seconds and than back on, it cools down and works fine for a few weeks again.
Any thoughts?
Michael
ArtStream is offline   Reply With Quote
Old 09-19-2006, 02:17 PM   #2
east stroudsburg , Pennsylvania
Originally Posted by artlink
Fridg question:
Any thoughts?
Michael
What model is it, and does it have the auto temp control on it?
RV_cool is offline   Reply With Quote
Old 09-20-2006, 03:33 PM   #3
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Hey RV Cool,
It's a 2820, Fan on upper fins and inside.
See, now its fine, but in a few days it will start to warm again, until I turn on and off?
Old 09-20-2006, 03:39 PM   #4
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
This was told to me my repair man...
The Amonia requires a compound to keep it flowing that if used on a slant, (not level) will start to separte and solidify.
This is not reversable.
Will slowly deteriorate the performance of unit.
Running down the road with it on is not a problem, as the movement keeps it mixed.
It only takes a few hours for this to happen.
Yours is probaly just starting to show signs of this.
The off and on, is opening up the passage that is trying to block up.
klattu is offline   Reply With Quote
Old 09-20-2006, 03:45 PM   #5
AirConditioner's Avatar
Check to see if it's going into an autodefrost cycle. Switching it on/off might shut off the defrost cycle. Just a guess - mine is 34 years old and doesn't do defrost!
AirConditioner is offline   Reply With Quote
Old 09-20-2006, 08:16 PM   #6
Hey RV Cool,
sounds like the temp probe or temp controller board is bad...probley the latter. When you cycle the power the board reboots itself.
Old 09-20-2006, 08:25 PM   #7
Level yes they have to be, because they rely on gravity to circulate. The only thing inside the units are 33% ammonia, 64% water, and 3% sodium chromate, and 350psi of hydrogen. Nothing separates out of this mix. If run off level, the sodium chromate tends to bake in the boiler and clog up the perkulator tube. If this happens, the unit will not cool at all, at any time.
www.snydersrvrefrigeration.com
Old 09-20-2006, 11:28 PM   #8
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Thanks everyone. RV Cool, I think I have a 3 year parts, is there a part I should be replacing befor it craps out?
Old 09-21-2006, 01:16 AM   #9
Since you got a part warranty I would have the circut board tested, any authorized dometic dealer should be able to do this.
Argosy Minuet 22' and 24' (1979?) overlander64 All Argosy Trailers 67 10-31-2007 10:17 AM
A good source for new parts/appliances! Anon Refrigerators 33 05-30-2005 09:26 PM
Forum Acting Weird Tonight Big Dee Forum Admin, News and Member Account Info 1 05-12-2004 08:44 PM
Idiot Lights Acting Up fangthorpe Mechanics Corner - Engines, Transmission & More... 4 11-29-2003 07:49 AM
