07-05-2005, 07:06 PM
freezer works great fridge to warm
I have a dometic rm100. The freezer works great on it. But, the fridge doesn't get cold enough. Is there anything I can do to correct this problem? Any answers will be greatly appreaciated.
07-05-2005, 07:43 PM
is the door seal working correctly? Put a flashlight inside the fridge and turn out all the lights in the trailer and look around the seal for light, that will tell you if it is or is not sealed.
Also how long have you waited for it to cool off? mabye give it a little more time.
07-05-2005, 08:17 PM
The door has a good seal. And the fridge has been running on ac for 3 days.
07-25-2005, 05:08 PM
I have the same exact problem. Freezer is very cold, the fridge is just slightly colder than outside temp.
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
07-25-2005, 05:45 PM
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands
, Nevada
Same thing here except that I think performance will be improved once it is filled up. try an experamint - load it up with bottles of water and see what happens. They do cool down quite a bit at night but warm during the day. Loaded the temperature will not go up as much. Also, gas or electric the vent to atmosphere must be clear to allow the heat to dissipate. make sure it is clear. Some have reported that a small fan in the vent pipe helps improve the temperature of the fridge.
07-25-2005, 06:04 PM
2004 30' Classic Slideout
Fenton
, Missouri
Could be a sign of impending failure. I know my fridge fell down on the refrigerator performance prior to its death. Freezer worked fine. I hope this isn't the situation for you.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-25-2005, 06:20 PM
Still Working
1994 36' Classic 36
North Charleston
, South Carolina
Classic
This definitley a classic sign of failure.
I am currently re-building my RM3807. The freezer has icemaker that works great!
Reefer section is warm.
I have researched much and it is a concensus in the RV refrig industry, FAILING cooling unit.
Sorry to be bearer of bad news but you can get plenty of info at this web site www.nucold.com or www.rvmobile.com there are other websites that will give you same info.
07-25-2005, 06:38 PM
1993 25' Excella
Full Time
, Anywhere USA
We had this issue in hot, humid weather
and have solved it by installing a fan on the outside the unit (but inside the access thingie) that we turn on to blow air over the coils. We also run a fan inside the refrigerator that we purchased from Campingworld for about $12.00 that runs on battery. Between the two fans we keep the refrigerator cool.
Michelle & Leon
New England Unit
07-31-2005, 06:19 PM
1978 25' Tradewind
Roseland
dometic fridge
Hi,
sounds exactly like a bad cooling unit. Try banging on the coils to see if you can get some more life out of it. A bad cooling unit usually means just ditching your old fridge and getting a new one, unless you can replace the cooling unit yourself, not an easy job. Get a norcold fridge for a replacement, cheaper and more reliable.
Eric
Eric, Tina and Kierstin Hedin
'78 Tradewind - Homeschooling RV Tech
08-02-2005, 12:52 PM
1958 26' Overlander
Mesa
Ditto. I had a Dometic 2804 and had the exact same
problem. Changed out the cooling unit but it only worked for an hour.
Finally went with a Norcold 641. Works great.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
08-02-2005, 02:00 PM
1993 30' Excella
whitewater
, north of cheddar curtain
ditto on the hot, humid weather...had an old residential servel. ran fine in the winter, not too well in the summer. finally died after 50 yrs...pilot safety was oem and wasnt made any more. threw it out rather then jury rig....safety,safety,safety....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
08-02-2005, 02:49 PM
1996 28' Excella
Okemos
, Michigan
As a fellow owner of a late 70's vintage RM100, here are a few easy things to try:
Use a 9" torpedo level to see if the fridge is really level. Ours was tilted relative to the trailer floor.
As mentioned before, put some jugs of water in there to give it some thermal mass.
Is your thermometer a bulb with external display?
Try running it on gas. The electrical connections for the 115 V mode may be slightly corroded. Cover the burner with some aluminum foil and rap on the chimney to get the shower of rust dust to drop out without plugging the burner before lighting it. The gas mode puts a lot more heat into the ammonia circuit than the electric heater.
Watch out for the controls. The old plastic adjusters get sticky and you may need to open the back to get it to switch modes. Just old plastic.
Good luck!
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
09-13-2005, 10:52 AM
1994 30' Excella
Milwaukee
, Wisconsin
I had the same problem with my RM100 but found it to be the flue stack was clogged. Dometic has an easy test you can do. Once your unit is lit open the door and feel the heat at the base of the burner assembly and then again in the middle of the flue stack by the asorbtion tubes. The heat should be the same if the flue is hotter at the bottom the flue is clogged. The clog can be anywhere along the flue and you may need to pull the unit to clean it out completly. I was lucky mine was right at the bottom. Now I will pull the burner assembly and clean that while I have it apart.
Follow this link for more info: http://bryantrv.com/docs2/docs/Mandiag.pdf
Chaplain Kent
Forest River Forester 2501TS
09-14-2005, 04:47 PM
1994 30' Excella
Milwaukee
, Wisconsin
Day two of my refrigerator fix. The freezer has ice and the fresh food compartment is as cold as it has ever been. Total cost of this fix was $0. and the repair guy said the it probably needed a new cooler. If I had put in a cooler it would have done the same thing and I still would have needed to clean the flue stack.
I did drop the burner, easy instructions on Dometic page. I was able to clean it completly and then really get inside the flue and get that cleaned out.
Chaplain Kent
09-14-2005, 09:03 PM
Just for the record......
My fridge was 35 years old. The first time that I tested it, I noticed greenish gold goo oozing out of the fittings ( deadly amonia gas ). The fridge section still froze eggs and milk. I said goodbye to the old fridge, and $1200.
The moral of the story.....check the fittings in the back of your fridge
09-22-2005, 07:01 PM
Bowie
I've got a RM 761 that is not cooling adequately. I read through the Dometic manual, and am not convinced that the fridge is completely shot. It is hot at the burner, and almost as hot at the Absorber vessel. The tubes above that are pretty warm to hot as well. I got dust out of the condenser today, but that did not seem to fix it. I can not see above the condenser fins.
Exactly what part are you referring to as the 'flue'. Is that the round vertical enclosure above the burner? Is it difficult to remove the unit for service, and checking and cleaning out the vents, etc? I want to believe that it is a ventilation problem. I think I got it level enough.
Need more info!
JMG
09-23-2005, 08:59 AM
John, the flue is the steel chimney. It is about 2 inches in diameter and extends the full height of the refer from the top of the burner. Instructions for cleaning it are at
http://www.airforums.com/forum...lue+brush+nick
Details are also on the Dometic website. It's a vital piece of routine maintenance. You may need to pull the refer into the central corridoor of the trailer for access to the top of the flue for inserting the brush. Good luck.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
09-28-2005, 06:23 AM
1994 30' Excella
Milwaukee
, Wisconsin
John
it would be worthwhile to pull the unit out and thoroughly clean the flue, this is not a difficult task. Instructions are given in the Dometic manual.
Chaplain Kent
09-28-2005, 11:37 AM
1977 27' Overlander
1954 25' Cruiser
VC Highlands
, Nevada
I am glad to see that this topic has popped up again.
I spent an hour blowing out my chimney and coils and flue. This gave me modest improvements to performance. I can say that being level is so very important. I found this out when we came back from our trip and found the freezer still cold but the fridge very warm. The trailer was parked on the slope part of the driveway and it was more than enough to make things not work.
In any event, we are going to replace our unit because it just doesn't work well and I suspect that it needs a charge of ammonia or may be partly plugged.
09-28-2005, 11:50 AM
Corona
Buttercup.
Before you replace your reefer, you might try another repair.
Cleaning and blowing out the flue really doesn't do much ggod.
What does make a huge difference, is the condition of the flame. Take the burner apart. Clean out the rust particles form the burner base. Soak the oriface in "Lime-away" for about a day. Reassemble the burner and then check the flame, at night is preferred. Check the LPG pressure. It should be 11 to 13 inches of water column pressure.
If everything is ok, with the thermostat turned wide open, you should see an improvement in the flame. You should also be able to hear the flame roar slightly.
Your reefer should now cool properly, as long as the freezer plate is level.
If not, then it's time to think about a replacement reefer.
The above suggestion, costs nothing, but it might save you hundreds.
