Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 04-26-2012, 01:17 PM   #21
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Have you checked the vent system for the refer? It sounds like the heat generated is not being dissipated effectively. That may explain why it seems to operate better when the ambient temp is around 50 degrees.
Old 04-27-2012, 04:23 AM   #22
1981 31' Excella II
New Market , Alabama
Does it work well when not in the trailer? My does not have fans and it works fine. The fridge freezes water.
Perry
Old 04-29-2012, 05:46 PM   #23
1963 28' Ambassador
Northern VT , Vermont
Sounds like you've covered normal steps. IF, big If, the freezer will reach and hold 25 or less try this when its up and running with a cold freezer. After dark put a flashlight in the fridge, shut the door, look for light around the seal. Give it a couple hours, check again. I had one once with the same symptoms. The door closed and sealed but when the interior started to cool the magnetic seal would separate from the case just a bit on the bottom.
putback is offline   Reply With Quote
Old 05-01-2012, 09:58 AM   #24
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
From your description, it is most likely that your cooling unit is kaput. It is not necessary for there to be leak to get the symptom of cold freezer and warm reefer. There is a powdered rust inhibitor in the ammonia solution that has percipitated out as crystals and they block the lower passages. You can get it running for a short period but it will continue to fail once this cycle starts.
You can replace the cooling unit yourself if you are comfortable with DIY ($350-400), have it rebuilt, or buy a new refrigerator. The cost of a rebuild by someone else can be pretty steep due to the time involved.
SeeMore is offline   Reply With Quote
Old 10-18-2013, 09:39 AM   #25
chisholmjb's Avatar
1986 32' Excella
1986 32.5' Airstream 325
Charleston , South Carolina
I had same prob. Then it wirks fine in gas but not electric. Dies anyine know how hard it is ti replace the ammonia tubing in the back of the refrigerator. I was told its nit that hard.
love camping go scouting. DO YOUR BEST
chisholmjb is offline   Reply With Quote
Old 10-19-2013, 09:33 AM   #26
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Its not hard, just tedious. Search YouTube and find a clip that shows the steps.
Old 10-19-2013, 01:56 PM   #27
chisholmjb's Avatar
1986 32' Excella
Good idea you have any links for that part
Old 10-19-2013, 02:01 PM   #28
Ottawa , ON
Here's one:
Old 10-19-2013, 02:52 PM   #29
Chillpoints's Avatar
1992 29' Excella
Asheville , North Carolina
I did not think it was tedious. Just take your time and put the ignitor and other parts from the old to the new. The hard part was getting the fridge out of the trailer so I could work on it. The switch only took about 2 hours going very slow to be sure I did it right. Works great now. Rvcooling wearhouse www.rvcoolingunit.net has good support and videos to show how it is done as well. Dont be surprised that www.rvcoolingunit.com is the same company. I purchased from them and would do it again if I needed to. Lets hope it continues to work for many more years. It sure was cheaper than a new one.
Jonathan Hettrick
'92 Excella 29'
'20 Ram 2500
AIR # 59179
Chillpoints is offline   Reply With Quote
Old 10-19-2013, 05:42 PM   #30
chisholmjb's Avatar
1986 32' Excella
Fantastic. Guys thanks. Im going to dig in in a week or so. Thanks
Old 10-19-2013, 06:09 PM   #31
Ottawa , ON
Probably a good idea to search on Youtube for "replace RV fridge cooling unit" or a variation on that.
The more you watch, the more comfortable you'll get with doing it and the more tips you will learn.
