Old 08-28-2014, 04:18 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Freezer Door Hard to Re-open
I have a Dometic refrigerator in my 2001 Safari that I believe to be the original appliance. If I open the freezer door after it has been closed a while, no problem. If I try to open it, say to put an ice tray back in after opening it to get it out, it is so hard to open I'm afraid I'll break the handle. If I wait ten minutes or so after opening it, it is easy to open. The problem does not exist with the refrigerator door, only with the freezer.
I suspect this is some kind of a vacuum problem, but I don't understand how the vacuum is created. I push the door closed until the latch clicks and no further. Maybe the freezer is filling with warm air which cools and the pressure lowers. The door opening is about 22x16, or 350 sq. inches. If the pressure differential was only 0.1 psi, the force exerted on the door would be 35#. After a while enough air seeps past the gasket to lower the pressure difference. The problem with this explanation is that the door is hard to open immediately, not after 30 seconds or so.
Any ideas?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-28-2014, 05:43 PM   #2
r carl's Avatar
Lin , Ne
I have the problem with both doors. What happens is warm air goes in when you open the door and when you close the door that air cools and creates a vacuum.
Old 08-29-2014, 01:23 PM   #3
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Same with us. I don't think we can hurt it by pulling a little harder.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 08-29-2014, 01:29 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Wrap 4 fingers around the handle but use your thumb to push in on the rubber gasket allowing a bit of air to release the vacuum inside. Alternately keep a PLASTIC scraper near the door and just slide it between the gasket and the door. zzzzzzzst - equalize pressure and open with ease.
Paula
Foiled Again is online now   Reply With Quote
Old 08-29-2014, 02:41 PM   #5
warbler5's Avatar
2004 30' Classic
Roseville , California
Send a message via AIM to warbler5
Get used to it....our 2004 has done the same thing since day one!
2004 30' Airstream Classic
2011 GMC 3500HD Duramax
Hensley Arrow hitch
Jackson Rancheria, 10-12 Oct 2014
Pinnacles Nat'l Park, 20-22 Feb 2015
Casini Ranch, 10-12 Apr 2015
AIR #6287
TAC #CA-26
WBCCI #3933/4CU
warbler5 is offline   Reply With Quote
Old 08-29-2014, 02:42 PM   #6
Thanks Paula. My fridge doesn't have a conventional handle, just an L shape that, at best, I can get two or three fingertips on. But I'll look for a place to push on the gasket. I've also thought about drilling a tiny hole somewhere to equalize the pressure.
It does sound like this is a VERY common problem!
Al
S/OS #004
Old 08-29-2014, 02:56 PM   #7
terryV's Avatar
2002 31' Classic
Monroe , Iowa
I don't know what causes it, but every camper fridge and freezer that I have ever had has done that. I think it means you have a good seal. Get used to it.
terryV is offline   Reply With Quote
Old 08-29-2014, 02:58 PM   #8
1976 31' Sovereign
Oswego , Illinois
door sticks
[QUOTE=Al and Missy;1503170]Thanks Paula. My fridge doesn't have a conventional handle, just an L shape that, at best, I can get two or three fingertips on. But I'll look for a place to push on the gasket. I've also thought about drilling a tiny hole somewhere to equalize the pressure.
Do not drill a hole any where in door or gasket as this defeats cooling status of frig. and freezer resulting in frig. running to try to keep temp., this common on reefer units as some like my deep freeze has suction fan that turns on when door is closed, after several min. inside temp is restored to setting allowing easy pull to open. Repeat DO NOT DRILL A HOLE ANY WHERE IN DOOR OR GASKET.
Old 08-29-2014, 03:23 PM   #9
Thanks for the warning
FWIW, I was thinking of 1/16 inch or less. I didn't think a small enough hole would affect performance.
Al
S/OS #004
Old 08-29-2014, 03:41 PM   #10
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If we have to have a tool to open maybe I can use my unused comb, no other use for it
I gave up on the reopen and don't close it when I will be putting something back in.
Old 08-30-2014, 09:25 AM   #11
1976 31' Sovereign
Oswego , Illinois
reefer door
[QUOTE=Al and Missy;1503183]FWIW, I was thinking of 1/16 inch or less. I didn't think a small enough hole would affect
Why have reefer if you want to let in warm air and defeat purpose of reefer as even a small leaking gasket causes frig to work hard to maintain temp and keep contents safe. Drill away you will have additional costs to run and shorten life of frig.
Domestic freezer door won't open!! LiLNomad General Repair Forum 4 08-21-2013 09:10 AM
Tambour On Kitchen Cabinets Hard To Open and Close JillyBean63 General Interior Topics 6 02-25-2012 07:55 AM
Thetford valves hard to open/close LI Pets Waste Systems, Tanks & Totes 7 10-08-2011 06:30 PM
Hard to open blt4spd Cabinets, Counter Tops & Furnishings 2 11-22-2010 05:01 PM
Hard to open windows!!!!! rv-n Argosy Motorhomes 4 12-19-2009 05:00 PM
