Originally Posted by eglisems Thanks for the update- Iam off to get a thermocouple at the local RV-
150 miles away - one way-
I will bring the old one....but can you tell me if there is a size or styly I should be looking at/ Are they rated for temperature?
Many Thanks! |
I don't think you have a thermocouple problem.
Since you have an older Argosy, the burner and it's oriface gets dirty.
You must remove both of those, clean them, and then reinstall the parts.
If that fixes the problem, you owe me coffee.
Also, you will need to clean the reefer flue, to remove the rust and dirt.
