Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 01-29-2018, 06:23 PM   #1
Teeter5
2017 25' Flying Cloud
conroe , Texas
Fan Replacement
Well I know there’s a ton of posts about he noisy stock refer fan and I’ve read most of them! I want to thank this forum the ideas on fan replacement ideas, mounting, etc.
Here’s my home made install, two aluminum angle iron brackets cut out for fan blade I take radius. I put a couple shims up top so the fan angle would pull air out the door louvers. Used the rubber isolator attach pins and no screws. Small tie wraps join them together (very tastiest and the rubber end pieces touching really help with vibration. Added a cheap NAPA toggle if I ever have a need to turn them off.
They are whisper quiet! Click image for larger version
ID:	303233Click image for larger version
Again thanks for the ideas on this forum.
teeter5 is offline   Reply With Quote
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 11:41 AM
Fan-tastic Fan Installation With Photos Dabler Roof Vents, Skylights & Fans 9 09-09-2007 08:18 PM
Fan-Tastic fan??? definition needed hex Our Community 26 10-10-2002 02:17 PM
Fan-tastic Fan installation BobbyW Roof Vents, Skylights & Fans 4 06-17-2002 09:40 PM
