Old 07-24-2009, 10:53 AM   #1
2004 16' International CCD
Bozeman , MT
Fan never stops! I want to sleep...
The fan on my refrigerator never (or rarely) stops. I try to ignore it in my sleep but doesn't really work http://www.airforums.com/forums/images/smilies/bb.gif. Is it normal that my refrigerator fan rarely stops? And what about the battery use? Seems like a battery drainer...
marchesi is offline   Reply With Quote
Old 07-24-2009, 11:11 AM   #2
1968 17' Caravel
wapakoneta , Ohio
There is a thermostat on the back of the refrig. set at around 90degrees.So when ever the compartment temperature reach 90 degrees it runs. You can get a switch to turn it off but the refrig may not cool as effectively.
Clipper is offline   Reply With Quote
Old 07-24-2009, 01:47 PM   #3
Bozeman , MT
Thanks for the info Clipper. Is this switch something that you need to have installed? I wouldn't mind to turn off the fan at night when I am sleeping...
Old 07-24-2009, 02:04 PM   #4
2002 19' Bambi
Lafayette , California
You will find lots of discussion about solutions to the fan noise here:
http://www.airforums.com/forums/f425...lly-11811.html
Tim
Tim A. is offline   Reply With Quote
Old 07-29-2009, 10:57 AM   #5
Bozeman , MT
Great info Tim.A!
Thanks!
Old 07-29-2009, 11:06 AM   #6
rgesch's Avatar
1956 26' Cruiser/Overlander
1967 17' Caravel
Newport , New Hampshire
Images: 18
This is what we have on ours. It uses very little D.C. and I can't hear it running, even in our 17' Caravel:
http://www.airforums.com/forums/f425...ese-22000.html
KB1UFH
KB1UFI
"Reality Is The Leading Cause Of Stress"
"There are only five great men in the world and three of them are hamburgers."
rgesch is offline   Reply With Quote
Old 07-29-2009, 12:32 PM   #7
2008 16' Safari
Destrehan , Louisiana
The fan is mounted to the reefer box. It acts like a resonator. Mine was so load it would wake me up at night. I mounted the fan to a 2X8 inch 1/4 inch thick rubber strip and then mounted the strip to the box. This leaves the fan in the same place but isolates it from the trailer. No more noise.
PM me if you want pics.
dlb435 is offline   Reply With Quote
Rest Stops janetb On The Road... 16 11-22-2007 08:37 AM
Rest Stops Minnie's Mate On The Road... 32 02-13-2007 07:26 PM
5,999 and he stops?!? mistral blue Off Topic Forum 21 01-12-2007 05:55 PM
Need more sleep... JaceBeck 1999 Safari 17 07-14-2003 09:36 AM
RV (Truck) Stops 74Argosy24MH Link Archive 5 10-28-2002 05:24 AM
