Old 06-18-2008, 10:47 PM   #1
HansenClan's Avatar
1965 26' Overlander
Encinitas , California
Images: 22
Electric Works, Propane Doesn't!!!????
What should I do? I have a 65 Overlander with an original refer. The 120v electrical works like a charm, cold cold cold! But, as soon as I switch it to the propane, it burns, and burns, and burns, but does no cooling and within a day it's warm...
Help!
HansenClan is offline   Reply With Quote
Old 06-18-2008, 11:01 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
The obvious answer is run it on electric, but I know you don't want to hear that.
It sounds as if the refrigerant is low and needs service - but then I know more about car A/C systems than refers...
Good luck with it.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 06-18-2008, 11:15 PM   #3
Help!
Reefer burners must operate at a certain temperature in order to create cooling, on both gas as well as electric. Since your reefer colls ok on electric, then the cooling unit is ok.
It is very common for a reefer that has some age on it, to have a dirty burner and/or a partially clogged oriface.
It could also have low LPG pressure. The LPG pressure should be 11 to 13 inches of water column pressure, but 12 to 13 inches is even better.
The burner should be removed for cleaning as well as the orifice. However, before you reinstall them, the flue "must" be cleaned.
What your reefer is doing, is very common, but not a big deal to fix.
Old 06-18-2008, 11:19 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Unfortunately, RV absorbtion refers don't 'get low on refrigerant' like A/C units will, and there is no 'recharging' available since they are all hermetically sealed units (but then again, you can't recharge modern roof A/C units either). In this case, if the unit works well on AC power, then there is a problem with the LP section of the boiler tube.
My guess would be a very dirty/rusted/corroded flue tube and probably a badly deformed spiral baffle as well, assuming the the LP burner is creating a nice, blue and intense flame. The spiral baffle is a flat piece of sheet metal that has been twisted into a spiral shape, and suspended into the flue tube at a very specific position. It is hung from a piece of piano wire from the top of the flue tube.
The spiral baffle's job is to create heat turbulence at this specific location in order to heat the ammonia solution (refrigerant) into a gaseous state, allowing it to rise up the pump tube into the condenser, where it mixes with the hydrogen gas, and this condensation process creates the cold that drives the heat transfer from within the refer box.
You might have to remove the refer from the cabinet in order to access the top of the boiler tube, but my guess is that proper servicing of the LP side of this refer will bring it back 100 %.
Let me know if you have any other questions...............
Old 06-18-2008, 11:44 PM   #5
HansenClan's Avatar
1965 26' Overlander
Images: 22
Well that's good news!
Thanks Andy & Lew! Hopefully I will be able to find and fix the problem, thanks to you guys...
Cheers!
Old 06-19-2008, 05:29 AM   #6
Uberphotos's Avatar
1968 22' Safari
Kalamazoo , Michigan
Hey Lewster...thanks a lot. Being a new owner of a 1968 Safari, I had no idea what that little squiggly thing was that is hanging down a tube behind my fridge...now I know...it is a baffle that is suspended into the flue tube and it has a purpose...I am always learning new things!!!
'68 Safari Land Yacht, Double
Check out my blog... http://ssairstream.blogspot.com/
Uberphotos is offline   Reply With Quote
Old 06-19-2008, 09:18 AM   #7
lewster's Avatar
............my pleasure..........
Old 06-19-2008, 10:08 AM   #8
Fyrzowt's Avatar
2000 25' Safari
Images: 8
I'm always learning something here...
AIR #15800
2000 Safari SS 25'
Old 06-19-2008, 10:26 AM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The good news is if it works on 120 the guts of the beasty are still good. Not every RV guy has the parts to repair them, but there are folks out there that can still do the job.
If the burner works you are ahead of the game. I am not an expert, but I do believe from the burner on up there is not too much technology that can go wrong. Ditto the above suggestions.
Old 06-20-2008, 09:04 PM   #10
HansenClan's Avatar
1965 26' Overlander
Images: 22
Thanks for everyones input! I am going to work on it tomorrow.
Old 06-20-2008, 09:29 PM   #11
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
Hey HansenClan,
Man, you received some sage advise from people with years and years of knowledge, I guess I should check out the function of my frig on propane, but I have never operated my refer on propane because I don't dry camp.
When I travel, I just use two 1/2 gallon heavy duty juice containers that I have saved and re-filled with water and froze solid. I place one in the frig and one in the freezer before leaving and everything stays cold/frozen for up to 12 to 18 hours.
When I arrive at the camp ground I plug into the electric grid and I never notice a difference.
I guess it is a cost to benifit ratio, how you use your Airstream Vs. costs to maintain features.
KeithC is offline   Reply With Quote
Old 06-22-2008, 02:35 PM   #12
HansenClan's Avatar
1965 26' Overlander
Images: 22
After a few hours of demolition, I mean removal, I free'd the refer from it's hole. Inspected, cleaned, measured and reinstalled the burner assembly and the baffle system. IT really didn't seem to dirty or out of alignment when I pulled it out! Hmmm...So, too hot (95 degrees) and too tired from a long half day working on the Airstream and the other half roughing the kids up in the pool, I slept without re-igniting the bastard. If all goes well and I am not sent to Northern California to fight the wildfires, I will light it off tomorrow, and patiently sit, watch, and wait....
Crossing fingers & toes...
Old 06-22-2008, 02:46 PM   #13
Lumatic's Avatar
1993 34' Excella
Images: 16
Eating Smoke
So another firefighter that likes to play with propane.
By the way, I tried fixing the safety valve on my fridge. There is a magnetic swtich that is activated by the thermocouple. Didn't help. So I jury rigged the safety switch open. The burner is only pilot light size and is vented out the bottom anyway. I also have CO, propane and smoke detectors in my AS. But I am sure there are those out there who will say I'm playing with fire (pun intended) The other alernative would have been to send the fridge out or replace it.
Marshall
Estancia Fire Dept. (one of my other hats)
Old 06-23-2008, 07:02 PM   #14
HansenClan's Avatar
1965 26' Overlander
Images: 22
IT'S PARTY TIME & IT'S ON PROPANE! Thanks to all who contributed! After all the fore mentioned muckery, I managed to not break anything else in the process, and fixed the refer! Thanks LADS!
I think my cerveza is cold now, gotta go....
Freezer works on propane - but not fridge adamstarr Refrigerators 2 08-14-2006 12:53 AM
Remove all Propane items...and replace with all electric leefields LP Gas, Piping, Tanks & Regulators 19 02-20-2006 05:57 PM
Propane/electric refrigerator B Stover Refrigerators 6 10-25-2005 12:01 PM
Propane/Electric Refrigerator jlh Refrigerators 4 09-19-2005 03:53 PM
New electric jack only works occasionally Zmod Jacks, Stabilizers, Lifting and Leveling 3 06-14-2004 08:09 PM
