Old 11-14-2011, 12:02 PM   #1
Anton66's Avatar
1966 17' Caravel
Sarnia , Ontario,
Electric fridge outlet
I want to replace my old dometic with an electric fridge, but the closest electrical outlet is the one above the kitchen counter(66' Caravel). It would be ideal if there was another outlet below the counter. Would this be hard to do, or is there a more obvious solution?
Anton66 is offline   Reply With Quote
Old 11-14-2011, 12:05 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Is your Dometic gas only and not gas/electric?
Bill
Just my personal opinion
Old 11-14-2011, 12:22 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
My '67 GT had a 110 volt outlet on the floor under the fridge. If you have the same setup it would be easy to move to accomedate the new unit.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 11-14-2011, 12:22 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
It is possible if you know a bit about electricity and putting a few holes in the interior skin. An easier suggestion is to use the flat wall channels like they do went the want to move an outlet in a house. That way you do not need to fish wires through the walls.
Old 11-14-2011, 12:23 PM   #5
Anton66's Avatar
1966 17' Caravel
Sarnia , Ontario,
old dometic
The original dometic is shot - its already been removed and I'm rebuilding the kitchen cabinet. I've already purchased the new electric fridge. I don't use gas at all - I just use electricity for everything.
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 11:14 AM
'69 Overlander Fridge: RM 2500 gas electric edglenn Refrigerators 1 09-07-2011 10:09 AM
New fridge on the Outs? skydiva Refrigerators 2 07-04-2011 03:04 PM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Skip the Fridge? (Overlander Newbie) pyrenees Refrigerators 15 05-09-2011 05:30 PM
