My fridge just went out on my Sovereign, and replacement is $1500!! What are the pros and cons for simply getting an electric one from Home Depot, I have a generator so boon docking is not a problem with electricity.
Do you want to run the generator 24/7 when you don't have hookups?
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Yea, I did not think of that, but it is a quiet Honda, so I guess that won't be too bad??? I really hate giving up $1500 for a fridge, my home fridge costs half that!
At 2 AM I don't want to be parked near you, but then I hate generators.
Bill
check out buying a rebuilt cooling unit...a believe pricing runs around $400.
If the rest of your frig is OK, this will make it like-new, in the cooling capacity.
The cooling units are shipped to you in a cushioned carton - your make the switch and return your unit back to the rebuilder.
Check the Net for a supplier - many RV dealers use these services as well, but you can do it yourself if you've got a few tools around...you've got to take the frig out of the RV either way, and that's half the battle...
Nick and I were posting at the same time (above) - there you go with some direct info on the cooling unit exchange...
__________________ Let us not be too particular; it is better to have old secondhand Airstreams than none at all. Mark Twain, updated (org...diamonds)
AIR # 11135
1978 - 28 ft Ambassador (Blue Halo)
2001 - Ford Excursion V-10 4x4
OK that may be true, I never ran them at night. Did I mention I really don't want to pay $1500 for a fridge??!!
I understand that you don't want to pay $1500, but with an all electric fridge, no generator running, no fridge working.
Bill
I don't know what kind of frig you have but I just replaced the cooling unit on my RM760 Dometic, yesterday. You can order a refurbished cooling unit from various sites, the one I used was www.mccampingsupplies.com. It cost me $430 with shipping and they had it on my door within two days. It took about 2 hours to replace. I could have done it faster but I went really slow to make sure that I did not screw it up and break something. This morning I went to the garage to check if it was getting cold and sure enough the freezer portion had ice in it. I still need to put it back in and test the propane.
I guess it just depends what shape your frig is in. Ours was like new even though it was a 1979 dometic. The cooling unit only comes with the cooling portion. You have to use the original heating portions, ie propane jets and electric heating element. I can not say enough on how easy it was. I was very nervous when I started yesterday.
Hope this helps. Oh by the way, about using your generator while out, it may end up costing you more in gas when all said and done. Plus while your in tow it wouldn't be cold, unless you can run the generator on the go like a MoHo.
I also forgot to ask if you tried to burp the frig. I just learned about this and it is in some repair books as well. If the propane and electric heating probe works, try taking the frig out and turning it upside down. It will mix the ammonia and water back together and possibly loosen any crystals that formed. This did not work for me but it is worth a shot. But if you have that yellow dust back there or the smell of ammonia then it is a mood point.
If I had to replace my frig, I think I would go with the electric only model, but most of the camping we do is local, in state parks, and electricity is included in the cost of the spot. I would think that it would depend on the kind of camping you do. It may hurt your resale, if you worry about that (I don't plan on selling any time soon). My refrigerator works on gas too, and I never (well rarely, once last year but I could have switched it over,just wanted to see if it would still work) use it. I guess you should do what you can afford, based on the type of camping you do.
I plug ours in, and fill it with food the night before, disconnect the electricity when I hook to the tow vehicle, and drive. The old refrigerator is insulated enough to act as a cooler while on the road. I just make sure I plug in as soon as I disconnect at the camp site. Then again, I don't take ice cream, but the meat is still frozen, and the milk is still cold...
Now that I think about it, the refrigerator in our camper didn't work on electric when I first purchased our trailer (loose wire) and it didn't slow my decision to purchase it one bit.
Good luck. Like I said I don't think I would miss the feature, but that is me...
Best Regards,
Scott
I have a picture of my Airstream in my wallet, and I'm sitting on it...
If you “Hook Up” camp you could forego the LP/Electric, and go strictly with electric. Our Avion has the Dometic LP/Electric, and our AS has electric only. I don’t boondock, and never have used the LP side of our Dometic. On short hops we use a cooler, and skip the fridge all together. Having the option of LP refrigeration is appealing. So…It is your decision, and as long as it works for you…
Best of Luck,
Kevin
__________________ Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
How did you switch your old unit out and replace it with an just electric one ? like to do that with mine, since I camp out at hook ip sites only.
PREP POTATO SALAD , THEN ADD MAYO WHEN I GET THERE
Thanks for the info. looks like a great idea. I wanted to put a fan in there with a thermostat and it looks like that kit has it already done for me. I just ordered it. I hope it comes this week so that I can button it up before my trip to the beach.
