Old 05-24-2015, 10:48 AM   #1
1969 23' Safari
Athens , Georgia
Cool Dumb Question
How do I connect my 12 v refer wires to my battery!
sarasafari is offline   Reply With Quote
Old 05-24-2015, 11:08 AM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Are you talking about 12v power to control the fridge circuit board, or is it 12v power to operate the fridge cooling unit itself?
BTW, questions are not dumb. Trying to do something without asking the question, now that's dumb!
Old 05-24-2015, 11:57 AM   #3
1969 23' Safari
Athens , Georgia
It was the wires connecting the refer unit to the battery. Got that one figured out, but now the blinking light won't go off while trying to use on gas mode. Just keeps clicking. Instructions say to depress ignition button til light goes out. It keeps clicking and blinking.
Old 05-24-2015, 12:24 PM   #4
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Sounds like an ignition problem or there is no gas going into the frig to ignite. 1st check and make sure there is gas to the frig, if so, go to ignition problem (electrical). Good luck.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 05-24-2015, 12:37 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Agree - and sometimes there is AIR in the propane line, or moisture. To clear air, Turn your stove on and manually light it. Let it run 30 to 60 seconds and turn it off. Then try the fridge again.
DO look at the propane line in the fridge, there may be a cutoff valve, and if the gas isn't on... well obvious problem.
If there is water in the line, you might hear gurgling in the propane line when you get underneath it. Just find the end of the line and open it after jacking the front end up so that the water will run backwards to the low point. Test for leak after you close up.
Old 05-24-2015, 01:22 PM   #6
Ottawa , ON
We know what trailer you have, but would you please share with us what make and model the refer is?
Most are Dometic brand, but if it's original to the trailer, all bets are off.
Old 05-24-2015, 02:58 PM   #7
1969 23' Safari
Athens , Georgia
I'm going to get thrown off of this forum. I had the gas turned off. ������
I've been working on this trailer for over 5years and am finally seeing the light at end of tunnel and am so excited that I can't think straight.
So I got the gas lit, let's see if it cools. BTW, while I was scratching my head over the gas issue, I was trying to run the refer on elec. but it never cooled down even one degree, over about 3hours time. Yes, I have it plugged into a high volt plug-don't know if it's 50 or 30. Refer is 2011 Dometic 2510, 2 way. But it's never been used or tested because of various personal issues which delayed me working on it. Oh, and thanks!����
Old 05-24-2015, 03:27 PM   #8
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
50 amp is a four prong plug and 30 is a 3 prong plug. Your AS should be 3 prong 120V 30 amp service. NEVER plug into a 220V outlet.
The control board for the frig works off 12VDC.
Do you have the frig control set for auto? The frig usually works on electric and defaults to gas when the Airstream is not plugged in to 120VAC.
Do you have the electric cord at the rear of the frig plugged in to a 120V outlet?
Could be the electric element that heats the frig is burnt out.
Garry
Old 05-25-2015, 05:47 AM   #9
Venice , Florida
Images: 14
Glad it was an easy fix. Most of my issues turn out to be projects. I am about to finally have a good time traveling with our Airstreamer!! Longest trip with it coming up!
Airdreamers
WBCCI #8880
AIR #41310
Old 06-08-2015, 10:59 AM   #10
1969 23' Safari
Athens , Georgia
Garry, it is 30 amp. Yes, the unit is plugged into a 120 v outlet. I checked the outlet and it is good. My unit does not have an auto setting. It's either off, gas, or electric. The gas is working, not the electric. Where would be the electric element? Could it be burnt out if it was never used? Any other ideas, folks?
Old 06-08-2015, 12:09 PM   #11
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Electric troubleshooting begins with the elementary things. Sometimes obvious, sometimes not so much. Find the 12v fuses and check them all with a test light. Sometimes they look good but are not. Start with the simple stuff and work up from there.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-08-2015, 12:12 PM   #12
Gainesville , Florida
Is the fridge plugged into a 120 outlet? In the back somewhere. Jim
Old 06-09-2015, 11:35 AM   #13
1969 23' Safari
Athens , Georgia
Jim, yes it is plugged in and the outlet is good. Roger, where are the 12 v fuses?
Dumb,dumb, and dumber rebel beck Electrical - Systems, Generators, Batteries & Solar 13 04-03-2006 11:11 AM
??Dumb generator question?? sjptak Generators & Solar Power 22 06-24-2003 05:24 AM
Dumb Question regarding the bed & sheets kamadeca 2003 Safari 8 06-23-2003 02:24 PM
My dumb question about holding tanks JaceBeck Our Community 6 12-07-2002 01:22 AM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
