Old 05-23-2008, 08:05 AM   #1
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
Dry Ice..
Hi all,
We have a working Marvel fridge that only runs on 120v. At this current time we prefer to do more boon docking than full hook ups. So my question is, does any one have experience with using dry ice to keep there fridge cold? If so were do the gasses go from the dry ice and do you keep it in the wrapper that it comes in. I have only used it to make fog for Halloween. I would like to get away from packing 2 coolers. One for food the other for beverages.
Thanks in advance for your help,
Custom driver license Pet ID's.
www.petidforme.com/105
1953 Flying is offline   Reply With Quote
Old 05-23-2008, 08:34 AM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Dry ice is just solid carbon dioxide. It sublimates directly from the solid to the gas. It will work fine if not confined, but it can generate beaucoup pressue if not allowed to vent. The vapor is heavy and mixes easily with the cabin air so you need ventilation. An old trick was to put a chunk of dry ice in a container with grain that needed to be preserved. The "ice" was allowed to "melt" and displace the air afterwhich the container was sealed to preserve the grain. When I worked at a paint store we would put a piece in a new 1 gallon paint can and seal it up and put back up on a high shelf. After a few minutes we were treated to a really loud bang! We used to get it free out inthe Mojave in the winter when the dry lakes froze, but by summer when we really needed it, it was all gone.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-23-2008, 08:56 AM   #3
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
First time we tried it in a Coleman ice chest it cracked the plastic liner. We used to freeze 1 gallon juice containers which would last at least 5 days with the new 5 or 6 day coolers. Today our Dometic in the '08 22 SS runs on propane or 120v and does a great job. No need for coolers.
Ahab is offline   Reply With Quote
Old 05-23-2008, 09:09 AM   #4
1953 Flying Cloud
Images: 8
I have also cracked an ice chest with dry ice. We kept our AS to the original design, Fridge and stove. It works why change it. If we wanted to up date to a newer fridge I would have to cut a hole on the side for ventilation of the propane. My better half would have my head if I did this. I'm more concerned with the gas matter being contained to a seal container. But then again I'm not 100% sure that the 55 year old fridge is air tight either.
Old 05-23-2008, 09:22 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I have read that there is a company that can modify the old 110 Marvel fridges that only runs on 110 vac to a new modern LP, 110 vac, or12 vdc cooling unit. Something to consider.
Kip
Old 05-23-2008, 09:33 AM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Kip
If that modification can be done, then the conversion to a DanVoss compressor, used on the Dometic Tundra and Nova Cool lines, is possible also and you don't have to cut vent holes. The DanVoss compressor runs on 110V and 12V or 24V.
Bill
Just my personal opinion
Old 05-23-2008, 09:46 AM   #7
1953 Flying Cloud
Images: 8
Bill
The only problem with running on 120v and 12v and not being plugged into shore power is it will drain my 2 marine batteries in about 12 hours.
I was also thinking of a frozen milk jug filled with water but that would take up to much space.
Old 05-23-2008, 10:12 AM   #8
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Robert,
The 7.5CF Nova Kool draws 3.2 Amps per hour on 12V, while running only. I have one for my Liner and also solar panels to recharge the batteries. I will be able to let everyone know how it works after the Liner is complete. Smaller units use less electricity, of course.
Bill
Old 05-23-2008, 10:14 AM   #9
1953 Flying Cloud
Images: 8
Robert,
The 7.5CF Nova Cool draws 3.2 Amps per hour on 12V, while running only. I have one for my Liner and also solar panels to recharge the batteries. I will be able to let everyone know how it works after the Liner is complete. Smaller units use less electricity, of course.
Bill
Wow thats not very much at all. I will have to look into it. Thanks
Old 05-23-2008, 10:19 AM   #10
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Robert,
Bill
I have this unit to be installed in my '67 Ambassador. It provides a large capacity for an under counter unit.
Novakool sells conversion kits that can be retrofitted to your Marvel box.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 05-23-2008, 01:07 PM   #11
2004 19' Bambi
Denver , Colorado
Images: 32
DO NOT USE DRY ICE in a confined space. OK to use in a cooler stored out of doors but it can kill you in your sleep if you try to use it in your camper. The amount of CO2 released can be enough to put you to sleep for good in a sealed, confined spcae like a camper.
See here for more info ... http://jama.ama-assn.org/cgi/content/full/293/13/1585
-Kevin
COLORADO_CAMPER is offline   Reply With Quote
Old 05-23-2008, 02:03 PM   #12
1953 Flying Cloud
Images: 8
-Kevin
WOW. Thanks Kevin for the info. I new it put off gasses. But I didn't know at such high rate. I guess there goes that idea.
I guess we will have to look more into the Nova conversion kit. I just feel if it's not broke then don't fix it.
Old 05-24-2008, 01:24 PM   #13
nilesrob's Avatar
Marietta , Georgia
Images: 12
See here for more info ... JAMA -- Brief Report: Acute Illness From Dry Ice Exposure During Hurricane Ivan--Alabama, 2004, April 6, 2005, 293 (13): 1585
-Kevin
Absolutely agree with Kevin. I used to use dry ice in an ice cream store I managed if we had issues with our freezer. The fumes are very powerful. My personal opinion - I would never use dry ice in a trailer.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 05-24-2008, 03:58 PM   #14
1953 Flying Cloud
Images: 8
Yes, after further investigation and great suggestions we have decided not to use dry ice. I have contacted Novacool regarding pricing for there 12v kits. I guess for the time being I will still have to pack a couple of coolers. This is one of the down falls of keeping every thing vintage.
As always there is great advise here on the forums. Much thanks.
Dry ice in Refrigerator bfred Off Topic Forum 4 08-01-2007 10:54 AM
Dry Ice to Remove VAT bevman Floor Finishes 5 04-13-2007 08:55 AM
Ice! 59toaster Off Topic Forum 30 02-04-2005 02:39 PM
Ice anyone? eljay Off Topic Forum 7 01-06-2005 02:55 PM
Dry ice and dents.... Silver Bullet Ribs, Skins & Rivets 19 11-13-2003 11:41 PM
