11-03-2016, 11:55 AM
2017 30' International
Dublin
, Ohio
Driving with Fridge on?
Greetings, new to all this.
I understand the fridge has to be level (i.e. airstream level) before turning on. But I have heard you run the fridge on LP gas while driving (as long as turn off before entering gas station). What if you are going up and down mountainous terrain, do you have to be concerned about the fridge not being level during these times?
Thanks in advance
11-03-2016, 11:59 AM
2002 30' Classic S/O
Fleming Island
From the Dometic Americana manual:
"Leveling is one of the requirements for proper operation with
absorption refrigerators. to ensure proper leveling the vehicle
needs to be leveled only so it is comfortable to live in (no noticeable
sloping of fl oor or walls).
Any time the vehicle is parked for several hours with the refrigerator
operating, the vehicle should be leveled to prevent this
loss of cooling."
and
"When the vehicle is moving, the leveling is not critical, as the
rolling and pitching movement of the vehicle will pass to either
side of level, keeping the liquid ammonia from accumulating in
the evaporator tubing."
Al
11-03-2016, 12:02 PM
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
I've never turned off the propane fridge when fueling either. Seems like a long way to ignite fumes. Maybe I have just been lucky.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
11-03-2016, 03:45 PM
Dublin
, Ohio
Thanks All!
11-04-2016, 12:07 AM
We don't drive with the gas on and haven't had a problem with food getting warm or anything defrosting. I mention this just to relay our experience, not to get in a discussion @ driving with gas turned on/off.
11-04-2016, 04:29 AM
Sag Harbor
, New York
On the issue of driving with the fridge propane turned on, here are some additional search results, as there are many earlier threads on-topic:
https://cse.google.com/cse?cx=011403...ing&gsc.page=1
Good luck, Mark!
Peter
11-04-2016, 11:34 AM
belen
, New Mexico
fuel vapors lay low. Is why home water hearers are now raised up!
Ive been doing this for 20 years and have NEVER shut the gas off unless im filling the propane tanks.
The LEVELING issue is only when sitting still for long periods!
11-04-2016, 12:57 PM
2016 22' Sport
Concord
Why not switch to electricity when moving? Isn't it safer than propane?
11-04-2016, 01:14 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
3-Way Fridge
For some reason, only the 22 Sport has a 3-way fridge.
Ray B.
11-04-2016, 01:37 PM
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands
That has never been a problem RV-ing for 40 some years. Frig setting for sometime for or aft is the problem. When parked. Moving up and down hills will not bother it. Trust me I never shout frig off while in travel.
11-04-2016, 01:38 PM
Len and Jeanne
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley
, British Columbia
There are HUGE debates on this forum about driving with the fridge on.
We're in the minority, but we just don't do this. Not because of the leveling issue, but because the propane could explode if you were ever in an accident while driving.
Our solution to keeping cold food cold when the fridge is turned off is to travel with 3 or 4 of those large blue gel freezer pacs. They go into the freezer when we're camping and stationary. Then when we drive, we turn off the propane and fridge, and put one or two of the frozen pacs go into the fridge area, with the food. We've never had food go off with this system. It works like a picnic cooler. The newer Dometics are really well insulated.
11-04-2016, 02:06 PM
Niagara-on-the-Lake
, ON Canada
The Best Kept Secret In Your RV’s Propane System!
Originally Posted by Len n Jeanne
... but we just don't do this. Not because of the leveling issue, but because the propane could explode if you were ever in an accident while driving.
Perhaps in old trailers and out-of-date propane cylinders, but in modern trailer systems which have the new style propane cylinder valves and the big ACME threads and with the big Green nut on the pigtail, then the propane will be limited at the valve if it senses an unusually high gas flow (not enough back pressure), such as from a broken supply line to the fridge, which could happen in an accident (or some other way).
However, if you are in an accident and the LPG bottles themselves are ruptured, then that could be a problem.
Here is a link to a 2001 article by Dave Shearer on this "secret".
Ray B.
11-04-2016, 02:08 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We have always traveled with the refrigerator on LP gas when underway. We have done this with three different Airstreams over the last ten plus years. We have almost 1,800 nights of Airtream camping under our belts, and we have towed our Airstreams over 150,000 miles all over the United States.
Running the highways with the refrigerator on is a personal choice that each Airstreamer has to make for him or herself. We choose to do it; others do not.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
11-04-2016, 03:40 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Just about all of the answers above are as close to correct as Damn is to Swearing.
Just remember when crossing the waters on a ferry boat, the propane MUST be shut off, or 'they' will certainly let you know about it.
11-04-2016, 03:55 PM
2018 30' Flying Cloud
South Hero
, Vermont
"Just remember when crossing the waters on a ferry boat, the propane MUST be shut off, or 'they' will certainly let you know about it."
Really? I was on a ferry twice in the last 2.5 weeks and was not told to shut off the propane. No signs to that effect either.
But, Lake Champlain is usually quite windy, so stagnant fumes shouldn't be an issue.
On an island in Vermont
11-04-2016, 03:59 PM
2012 25' Flying Cloud
Berlin
, Maryland
Many of us travel with the fridge running on propane, however, there are restrictions such as traveling the bay bridge tunnel that crosses the Chesapeake in Virginia. There it must be off. Also in Maryland you cannot even use the tunnels in Baltimore if you are traveling with propane tanks. So I always check ahead of time when I am going to go through tunnels
11-04-2016, 04:12 PM
2016 30' Classic
Santa Rosa
You can run the fridge without propane if you are on shore power (120v). However, while traveling, you have to use propane AND leave the Use/Store switch in the Use position so there is 12v power for the fridge circuit board. It can't cool on 12v electricity without propane.
Happy Trails,
Phil
11-04-2016, 04:15 PM
Niagara-on-the-Lake
, ON Canada
The Sport 22 has a 3-way fridge and will run from the battery while travelling.
Ray B.
11-04-2016, 04:45 PM
2004 30' Land Yacht 30 SL
Surprise
When running with the refrigerator off you need to consider how often you open it. Put a thermometer in the refrigerator with door closed. Open the door take somethings out and close. Do that several times and the temperature will climb to much higher level (>50deg). Your use on the road will help you make the decision to leave it on or off. Food safety is the bigger concern in my opinion.
