Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 05-26-2012, 07:22 PM   #1
2004 16' International CCD
Orem , Utah
door repair on refrigerator
ok the 3 screws on bottom kept coming loose while traveling down road. Is there a way to remove the door so I can see whats going on in threads. If I can get this off and make sure there biting down, blue loc tight on screws.
starcraft is offline   Reply With Quote
Old 05-26-2012, 08:09 PM   #2
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
any photos?
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 05-27-2012, 02:50 PM   #3
Orem , Utah
got it
once I used thin string to pull knobs off the unit came out top. Then I could see 10mm on top and below the door. Comes off pretty easy, remember the washer and nut on bottom part door.
