Old 08-17-2011, 01:39 PM   #1
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Dometic working on shore power, but difficult to get it running on gas
We are getting ready for a long weekend trip and I always start the refrigerator a day or two ahead to get it good and cold prior to loading the TT for the trip. It usually takes a couple of attempts to get it started (so the LP fault light doesn't flash). However, this time I have tried to re-start it 6 or 7 times and after about 10 minutes the LP fault light starts flashing. Gas is on (both tanks), burners on the range top are working, but the refrigerator wasn't getting started. I had presumed that the problem getting the refrigerator running on previous trips was due to no gas in the line and it just took awhile to fill the gas line and get it going. While trying to get it started again this morning I could hear it go whoosh, but the pilot light still didn’t appear to stay lit. I used a long nosed lighter and could hear it go whoosh again while keeping the flame on the thermal couple in an attempt to get it heated, but it still didn’t look lit. Now I am wondering if the thermal couple was starting to go bad and is now non-functional. If it is the thermal couple, how easy or difficult is it to replace myself, or is it a job best left to a repair/service tech. Worse case for this weekend, we pack a couple of coolers to use until get hooked up to shore power at the CG and the refrigerator cools down. Not my first choice, but...
Late Breaking News: Just got an e-mail from my wife, and the refrigerator is starting to get cold. But I am still concerned about the thermal couple. Is it on its last legs, or is this just normal operations? I really don't want to go through this every time we get ready for a trip.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 08-17-2011, 02:00 PM   #2
VIKING's Avatar
Boulder Creek , California
Thermocouples are usually very easy to replace if you can find a replacement in time. It could be a piece of dirt in the burner also. I would clean it before purchasing any new parts.
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 08-17-2011, 02:17 PM   #3
Scott J-24's Avatar
Best to you,
Rich the Viking
Rich,
What is involved in cleaning the burner? Do I just remove the windscreen and clean with cloth and little soapy water? Are there any special tools or such that I will need to clean the gas lins or flue? Sorry for all the questions, but being a rookie, I am still in the learning curve.
WBCCI #1215
Air #54601
Old 08-17-2011, 03:10 PM   #4
VIKING's Avatar
The part that gets clogged in mine is the burner orifice. It is a small brass fitting with a tiny hole for the gas to flow through. You must not damage it or ream the hole out larger than it is. Just a gentle cleaning and blowing it out was enough for mine to clear. You should be able to remove it with a wrench for cleaning.
Best to you,
Rich the Viking
Old 08-17-2011, 04:15 PM   #5
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Sometimes it is better to use a vacuum to clean, and I think the wires from a wire brush fit the last time I did this.
Also next time you have to refill tanks, start gas flow by turning on a eye at the stove... and lighting of course.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 08-21-2011, 11:56 PM   #6
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
To clean the orifice, use denatured alcohol ONLY! The laser cut ruby inside the hole is easily damaged by a wire or pressurized air. Remove the brass fitting (after cutting off the propane at the tank) and soak it for 25 minutes (submerged). Let it air dry for 15-20 minutes and reinstall.
SeeMore is offline   Reply With Quote
Old 08-26-2011, 04:01 PM   #7
your situation sounds just like mine is acting. I took mine to local RV repair today and of course the refrig started right up on gas. They said problem might be one of two items. (1) The unit that creates the spark (on my 2005 Safari it is to the left of the gas chamber and has a black cover with 2-3 small wires coming out. (2) or the wire delivering the spark might be bad (mine is very small, clear/white and runs to a probe beside the gas orfice. DO NOT remove the wire from the black component except with insulated plyers or you will get a really big electric shock.
With insulated plyers, remove the white/clear tube from the black unit (after removing the black cover). With the plyers, hold the black unit wire end close enough to the spot it was removed from and check that you are getting consistent sparks.
BTW, everytime your refrig reaches temp, the gas flow shuts off and must later be restarted. Thus, on initial start or restart, the failure to ignite and thus 'check' indicator can occur anytime.
Beyond that, I cannot help. The black unit retails for $35 and the wire unit for $30.
Neil Ervin, Sequim, Washington (on the north edge of the beautiful Olympic Peninsula)
neil.ervin is offline   Reply With Quote
Old 08-27-2011, 01:01 PM   #8
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Read the Service Manual
If you want to better understand and repair your Dometic Reefer download the service manual PDF here:
Dometic refrigerators - Download Dometic Manuals
Old 08-27-2011, 05:44 PM   #9
Scott J-24's Avatar
Thanks for the link. This should give us what we need.
WBCCI #1215
Air #54601
Old 09-06-2011, 11:44 PM   #10
Scott J-24's Avatar
Problem Solved
After cleaning and blowing out the gas orifice, the refrigerator still would not light. The next step was to replace the igniter wire and probe. That did the trick, now it fires up in the first ignition cycle. One problem down and now on to the next... an intermittent leak at the city water inlet, but that is a topic for a different thread! Many thanks for all of the replys, leads, and suggestions.
WBCCI #1215
Air #54601
Old 09-06-2011, 11:51 PM   #11
tpi
Trabuco Canyon , California
"replace igniter wire and probe"
If it is what I think you mean, the official Dometic name for this is the "electrode." A thin wire leading to a spark plug like device which also senses the flame.
I'm on my third one, the original and two replacments FWIW. They seem to last me about two years or so. They seem to fail when its cool and damp outside.
tpi is offline   Reply With Quote
Old 09-07-2011, 02:07 PM   #12
Scott J-24's Avatar
Yes, it was the electrode. Guess I should pick up and extra and keep it in my spare parts kit.
WBCCI #1215
Air #54601
Old 09-07-2011, 02:29 PM   #13
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
and if you don't have a spare electrode (or flame sensor?), try a little fine abrasive like an emery cloth, or wet or dry paper, or a fine file to "clean" the portion of the electrode that would be in the flame back to fresh metal.
this will often work for you.
ymmv.
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 09-07-2011, 02:33 PM   #14
Scott J-24's Avatar
ymmv.
best,
Turns out that the wire attached to the electrode had a break in it (inside the insolation). I probably should have checked for continuity earlier than I did.
WBCCI #1215
Air #54601
Shore power requirments for trailers Mrcrowley Generators & Solar Power 21 08-02-2017 05:20 AM
Complacency In Today’s Economy Spells Vanishing Tanks and/or Shore Power Cords! overlander64 Our Community 34 08-18-2011 11:58 AM
Dometic not working on 12V, ok Elec & Gas afordjones Refrigerators 1 08-16-2011 06:02 AM
HUM from radio when hooked to shore power The Driver Audio, Video & TV 5 07-12-2011 05:42 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
