Old 08-17-2011, 08:37 AM   #15
1982 31' Excella
Burlington , Ontario
you guys are amazing with your snappy replies!
How about 29 yr old Dometic working on Gas and Elec but not on 12v? I have established, with the help of Wasagachris, that I only have 7 pin plug so I can understand why there is no direct 12v feed to the fridge from the car, but why is it not working on the 12v from the A/S itself, independent of the car? Your wisdom will be greatly appreciated.
Anthony (Newbie)
afordjones is offline   Reply With Quote
Old 08-29-2011, 02:35 PM   #16
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
HI
If you have a 3 way fridge, there is a 12 volt heater that fits in alongside
the 110V heater. This heater pulls up to 25 AMPS and needs a really hefty
12 Volt source. Pick up a cheap multimeter at radio shack or Home Depot,
unplug the shore electric, and turn on the 12V control, in the back of the unit
check and see if you truly have that, your manual, or get one online will
show the proper terminals. Then disconnect one terminal, and check the resistance of the heater, should almost show a short, but if a high reading it is burned out. I am going through this withmy fridge, found a number of sites on line that have the parts. PPL motor home among others
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 02-03-2017, 09:03 AM   #17
Newbie
1975 31' Sovereign
Dublin , Ohio
Originally Posted by TG Twinkie View Post
@ Gosman:
Do you have the electric side thermostat set to at least 5? If so and it's not getting cold it could be the heating element.
First: Get your meter out and make sure there is power to the refer.
Second: With the refer in the electric mode and thermostat (electric) turn all the way to max. If I remember correctly the white cable (held down by a double screw clamp) is the 120 volt AC power to the refer, you can check for power at these terminals.
Third: Check the voltage at the terminals that power the heating element. In the photo I posted, the wires in the rust colored sheath are the heating element wires. You can see they are terminated on stab connectors. If you have 120 volts AC on these terminals, then the chances are good that the element is bad.
You will need to remove the sheetmetal cover(s) on the lower right rear of the refer; also remove the insulation. The heating element is located in a well, follow the wires. It just slides up out of the well.
Caution: Should you decide to remove the element, make sure you have the power OFF.
I know this is an old thread but I can't seem to find this answer ANYWHERE. you mention if the voltage is good at the terminals for the heating element that the element itself would be bad. What if there is no voltage at the terminals of the heating element? I removed it and it measures in the right ohm range (upper 40s) and has continuity. But after testing the voltage where the power cable hits the combiner box and it reads 114, why would I get a zero reading where the heating element leads connect to the combiner box? Any help would be greatly appreciated!
airsovereign is offline   Reply With Quote
Old 02-03-2017, 09:18 AM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Not sure what you mean by combiner box.
Have you selected the electric mode?
Have you set the thermostat to the highest setting?
Do you have power to the thermostat?
Can you post a pic of the back of the refer showing the terminals etc?
TG Twinkie is online now   Reply With Quote
Old 02-03-2017, 09:58 AM   #19
Newbie
1975 31' Sovereign
Dublin , Ohio
Thanks for replying! Yes I have it set to electric with the thermostat cranked to 7. The combiner box is where all the wires combine, as shown in the photo. I tested the voltage at the thermostat and got .4 volts. I tested the voltage at the switch and got 118v. Does everything look wired correctly? If the thermostat is bad would that be why there is no voltage at the heating element lead connections?
ID:	279130   Click image for larger version
Old 02-03-2017, 10:11 AM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Dometic working on propane, not electric-just one more mystery
First check for voltage at terminals 1 and 2. If OK then
Terminals 1 and 4 then
Terminals 1 and 3. Let us know the results.
You might try disconnecting the terminals and cleaning them. Be sure the power is off.
Old 02-03-2017, 10:13 AM   #21
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Xxx
Old 02-03-2017, 10:19 AM   #22
Newbie
1975 31' Sovereign
Dublin , Ohio
Voltage at 1 and 2 is 118v
voltage at 1 and 4 is .4v
voltage at 1 and 3 is 0.0
Thanks!
Old 02-03-2017, 10:23 AM   #23
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Either the switch is bad or not on.
Old 02-03-2017, 10:28 AM   #24
Newbie
1975 31' Sovereign
Dublin , Ohio
Do you mean the thermostat? When I put the leads on the wires coming out of the switch that's where I get 118 volts. The wires coming out of the thermostat give me a reading of .4 volts
Old 02-03-2017, 10:29 AM   #25
Newbie
1975 31' Sovereign
Dublin , Ohio
Also the knob you turn to electric inside the fridge, it goes 360 degrees. It feels like there is some resistance like it's turning something but should it go all the way around like that or should it stop somewhere?
Old 02-03-2017, 10:31 AM   #26
Newbie
1975 31' Sovereign
Dublin , Ohio
And is there a way to turn the switch on from the backside of the refrigerator if it's for some reason not grabbing from the knob on the inside of the fridge? Thank you SO much for your help.
Old 02-03-2017, 10:41 AM   #27
Newbie
1975 31' Sovereign
Dublin , Ohio
I found where the switch connects to a white plastic piece that rotates when you turn it. It was stuck behind a piece of metal. I pulled it out to clear the metal shield it was stuck on and now I hear lots of liquid moving around, I think it's fixed!!! Thank you so much!! I'll report back in a few hours to confirm
Old 02-03-2017, 10:43 AM   #28
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
When you look at the schematic. Follow the wire from terminal 2. It goes to the switch then terminal 4. If terminal 4 is hot the switch is OK.
The full rotation of the switch does not sound right.
Try removing the knob. If you can rotate it with pliers or screwdriver. It should only select between (gas) (off) ( electric) as I recall.
propane gas leak (rotten eggs) 2010 International stench wendywoods LP Gas, Piping, Tanks & Regulators 20 12-01-2011 02:34 PM
Dometic RM100 not working mmcpherson Refrigerators 21 04-28-2011 08:37 AM
Propane phobia. ROBERTSUNRUS LP Gas, Piping, Tanks & Regulators 18 04-27-2011 11:37 AM
Electric working with battery not with 110 TX_DB Electrical - Systems, Generators, Batteries & Solar 11 04-24-2011 07:19 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
