Old 04-10-2010, 12:21 PM   #1
1972 27' Overlander
Painesville Twp , Ohio
Dometic won't stay lit
I have a new-to-me 1972 Overlander with a newer Dometic fridge. It is an AC/Gas unit. Works ok on AC. Not very cold. I just got my gas tanks and lines updated. When trying with gas, the gas ignites, and then goes out 1-3 minutes later. Anyone know how to fix this?
Gas cooktop works, so I'm pretty certain it's getting gas.
Nick
hagnik is offline   Reply With Quote
Old 04-10-2010, 06:33 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
How long ae you waiting to check on how cold it gets? It usually takes about 20 hours to get the whole box cooled down. I would check the thermo couple to make sure it is in contact with the flame. When the thermostat calls for the burner to kick back could be when it goes out. If the thermocouple looks all fuzzy and has junk on the end, you might try cleaning it, but it probably should be replaced.
TG Twinkie is online now   Reply With Quote
Gas Water Heater Won't Stay Lit somefun LP Gas, Piping, Tanks & Regulators 13 11-02-2010 04:32 PM
Water Heater will not stay lit Beginner Water Heaters, Filters & Pumps 8 04-01-2008 01:08 PM
Pilot light won't stay lit abridges01 Refrigerators 5 09-24-2006 11:01 PM
Pilot Light won't stay lit Mike Callaha Water Heaters, Filters & Pumps 15 03-26-2005 12:56 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
