Old 04-14-2010, 02:50 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Dometic vs Norcold, any thoughts?
I wanted to make a specific post, Dometic vs Norcold. I'd like to know people's experiences with performance, service and design- someone posted about a good detail with the Norcold, recessed floor, which made it less messy to defrost. The Norcold appears to only come in electric or gas, not 3 way. We're looking at the 2.7 cuft model for under the counter in our '64 Globetrotter. Maybe electric is fine, if it will run off the battery, with solar back up? Also, if we do away with the gas, is it a bad idea to remove the *&%$ fridge vent on the roof?
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Should I replace Dometic with a Norcold? 48Bob Refrigerators 6 04-26-2010 12:52 PM
Thoughts on used Norcold 6052 slimitch Refrigerators 2 12-09-2009 05:08 PM
Dometic vs. Norcold Globie64 Refrigerators 8 10-20-2009 06:18 PM
Norcold vs. Dometic biggoofball Refrigerators 18 06-06-2008 10:21 AM
Dometic or Norcold JimGolden Refrigerators 8 07-02-2007 11:37 PM
