Old 02-15-2012, 09:05 PM   #1
1972 23' Safari
Atlanta , Georgia
Dometic Thermocouple
Can anyone direct me to a previous thread for replacement of the thermocouple on my Dometic refrigerator from a '72 Safari? I was able to find a replacement thermocouple (correct part number and such) for what I believe is an old and nonfunctioning thermocouple, but the new part did not solve the problem of maintaining the pilot light once the manual valve is released. Worried that without the gas operation my boondocking days may be doomed
Maybe there is some trick to installling thermocouples that I am not aware of...the one for the water heater seemed straightforward enough last year....
drcamo is offline   Reply With Quote
Old 02-15-2012, 09:15 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
From my 75 service manual:
ID:	151221   Click image for larger version
Richard
Old 02-15-2012, 10:19 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Make sure the part below part "a" is pushed firmly down into the valve and then tighten the nut. Do Not over tighten.
TG Twinkie is online now   Reply With Quote
Old 02-15-2012, 10:45 PM   #4
1974 Argosy 20
Kooskia , Idaho
the part A must be tight, but not too tight. And clean when you install it.
Also, must be in the flame enough to keep it hot.
Old 02-15-2012, 11:08 PM   #5
1974 Argosy 20
Kooskia , Idaho
I thought of another reason you may not have flame after the button is let up.
The older units, like yours, had a 2 level flame. The high level is the one which does cooling when the thermostat calls for it, otherwise the flame falls back to the lower level. There is no pilot light on those refrigerators, only high flame and low flame.
So, high is controlled by the thermostat, low is fed by the "bypass" screw opening. If the thermostat is at it's lowest position and not calling for high flame, and the bypass opening is plugged the flame will go out when you let go of the reset button.
Try this: Be sure the cold control is turned up as high as it will go, then try lighting the unit. If it lights, but then goes out when things cool down, you need to clean the bypass opening. It has been a very long time since I have done that, but as I recall it is a little brass head nut like thing on the side of the gas valve the thermocouple goes into. Or, if you have instructions, they may identify it.
So, the gas for low flame goes through the bypass opening, and for high flame it goes through the thermostatically controlled passageway. If the thermostat says it is cold enough or is in the off position, and the bypass opening is plugged you will not be able to keep the flame on.
I hope that helps if the thermocouple ideas do not.
Old 02-16-2012, 11:39 AM   #6
1972 23' Safari
Atlanta , Georgia
Thank you all for your insights and I will try these things when I get down to my home away from home.
TC
Dometic Refrig no lights on panel texascanuk Refrigerators 6 01-30-2014 06:51 PM
New Dometic Heatpump needs help! ExcellaFella Furnaces, Heaters, Fireplaces & Air Conditioning 11 02-24-2012 07:29 AM
Dometic RM3807 Refrig Diode problem? lmcatee Refrigerators 1 02-07-2012 07:52 AM
Thermocouple for Royal Dometic? MATTY J Refrigerators 12 01-31-2012 07:06 PM
Dometic Part Supplier? urban71 Refrigerators 3 01-18-2012 07:53 PM
